Kicking when Driving uphill
QC4X4
CA
Hi, we have a 2001 Expedition and we notice we get kicking noises when driving up hills and when we give it gas it does it a lot when driving to upper elevations at Freeway speeds any Help would be appreciated
Thanks
toms89
technical advisor
MD
Kicking noises?! Any other symptoms or description?
Ignition miss?! Is the motor running smoothly at the time?
Possible suspension issue. Have you checked you rear control arms? They have been known to rust out, at least in the snow belt, and this could lead to misalignment of the rear and cause all kinds of issues.
toms89
technical advisor
MD
Really could use some more info because I can think of a 100 potential things.
Is it something you can feel or just hear? Can you feel it in the steering wheel? Does it feel like its coming from the rear? Is the motor effected?? etc.. etc...
Be as descriptive as possible.
Lightnig
Behind you
I'm stuck trying to imagine what a kicking noise would sound like...confused.gif
Kicking a tree? Kicking a dead cow? Kicking a car door? Kicking a brick wall? Barefoot? Sandles? Rubber boots? Ballet slippers?
Q
QC4X4
CA
Hi, thanks for the help there is no missing engine runs smooth transmission tries to shift to a lower gear when going uphill even with overdrive off and it kicks but does not slip does not happen all the time
Thanks
BigJuicy02
Hinesville, GA
Had a similar issue in the wife's durango. No noticeable drop in rpms. Took a couple of months and it finally got bad enough to see the rpms fluctuating. Started acting up on flat roads too. Turns out the catalytic converter is partially plugged. I will be fixing this on Saturday along with adding a flowmaster. Not saying this is the issue but it is a possibility. Keep us posted.
cavakilla
indiana
My educated guess would be a coil pack is starting to die, second guess would be fuel pump.
