Engineer1225
Hi,
I just can not for the life of me get this manifold to seal. I've tried all forms of gaskets;
- OEM MLS style
-Steel Core Composite (Fel Pro)
-Steel Core Graphite(Also Fel Pro same part number as the one above, they changed materials on the updated one.)
-Mr. Gasket "Dead Soft" Aluminum Gasket
-The junk worthless fiberglass? paper looking one that came with the Dorman manifold
I got my original Ford Manifold planed by a shop, as well as that piece of junk Dorman one.
I'm coming to find out on my own that Dorman makes complete garbage. The new Dorman studs and nuts I had to chase out the threading......stock they had friction? what?
The Dormans manifold casting was really off on the first one I bought, switched it out under warranty and the second ones flange threading did not hold up when I went to torque. Garbage.
Checked for leaks and cracks on the Ford manifold, none were found. I cleaned and chased all stud holes. I torqued at the correct values and in the correct sequence in accordance to how the Ford Service manual states. The only thing I have not checked is for warpage on the cylinder head exhaust port itself, that has to be the problem. I don't have a quality straight edge yet. Other possibilities is my torque wrenches are no longer withing the -/+ 4% tolerance. They're a few years old, I haven't got them calibrated. (How off could they really be?)
I've tried double gaskets. Copper RTV alone and with the gaskets.
I got it to seal ONCE and only once. It was with the Aluminum Gasket no RTV. The sound came back after 30 minutes, retorqueing had no effect. SO I know this manifold can be sealed.
It's really boggling my mind here.. Anybody ever heard of "Remflex" Gaskets? They're just thick pieces of Graphite aren't they? Would this gasket be worth a try? I'm unsure because if the RTV isn't sealing then what will.
Can Anybody recommend a person or shop that I can take this to if I need to? I don't know who I can trust. I don't trust the clowns at the Ford Dealership, they don't know how to work on these older cars, my father got shafted twice trying to get them to fix the electrical problems. I ended up having to fix it myself.
- OEM MLS style
