You sure you have the proper bulb model for the low beams? Look at the Halogens and make sure the tabs are the same on the bulbs. Also, the LEDs should match up exactly with the placement of the Halogens filements.I was able to rotate the ring but wasn’t able to get the bulb back in due to the base of the bulb and the way the housing is on the sides
