rob4092xx
Is there a switched on positive wire anywhere under the hood that I can use? A wire that is hot when the engine is on and is dead when the engine is turned off? 2017 Expedition.
Try the wirung for the wiper motor.
I am going to wire the LED fog lights so they are on when the engine is running. The require almost no amperage since they are LED.Just make sure you use a circuit that is rated for the device you plan to use. And MOST important DO NOT INCREASE THE AMP RATING OF THE FUSE
For what purpose do you need the circuit
