Loose Transmission Shifter
Jonnyrocket
Phoenix Arizona
I'm new to the forum and wanted say thanks for all of the solid info available here. I recently purchased a 1st Gen Expy and it clearly hasn't been loved for the last 10 years. After getting the engine to fire on all 8 with new coils and plugs the next order of business was the super sloppy trans shifter. Starting with a good lead found on this forum I located two loose star bolts holding the shift cable to the end of the shift column. You have to do some yoga to get all up under there to see and tighten them. This helped but it was clear something else was really wrong here. I tilted the wheel down, removed the plastic steering column covers and could easily see a broken shifter clamp. I ordered a Dorman 901-110 Shift Tube Clamp kit online for $12.13 and when it arrived I dug into the repair.
Oops, don't you love it when you're doing something for the first time and you get an "aha," moment? On closer examination I learned there is another clamp w/bushing further down on the shifter tube and this one was broken as well. To get access to this second clamp I had to lower the steering column assembly which is not as intimidating as it first looks. After removing the large lower plastic dash piece there is a 4 point tubular bracket with 4 nuts, I removed those. There are 4 additional nuts holding the column in place. I completely removed the front two and then loosened but left in place the rear two so that the steering column was still supported. While working on it I heard some metal pieces drop, yikes what was that, what are those? There are two metal, spacer inserts that slide over the front 2 column studs. If you do this repair see if you can remove those before they fall on their on.
Now I needed another tube clamp kit. Turns out the local parts house had the same Dorman kit in stock for $19 and they price matched my previous online purchase. BTW-I didn't pressure them into the price match cause I think brick & mortar stores have a right to make a profit but the counter guy insisted. To those of you doing this repair go ahead and purchase two replacement clamps first and replace them both while you are in there.
There was a gray, sludgey mass of goo where the old bushings had been so I cleaned this thoroughly and used dry lube on the new install.
While I had the column down I replaced the shifter lever as well. The overdrive button had broken off of the end and the rubber dust boot had disintegrated. Looking online I had a hard time finding a unit with the dust boot and finally ordered the following: Genuine Ford 4L3Z-7210-BAA Transmission Gear Shifter Lever with boot and overdrive Off indicator light from Wholesale Direct Parts for $54 bucks. Amazon indicated that this unit would not fit my 97 Expy but it did just fine.
The last on my list for this project was the shift indicator pointer was off. Closer examination showed the small white plastic piece that holds the cable adjuster for this mechanism was broken. I wasn't sure if I could get this piece and I was excited to try out the shifter repair so I slapped on 3 small zip strips to hold it together.
Wowsa what a difference!! The shifter is solid and smooth now. Tools used in this repair were: phillips screwdriver, 7mm and 8mm 1/4" sockets, 15mm 3/8" socket, T30 star bit and dental tool to remove the ignition switch assembly.
98eb5.4
s. ontario
good stuff ty! i need to go over mine & only heard/read about the usual 2 star bolts u mention
Maximus
When you say 'loose' do you mean that the shifter would kinda wobble a bit after say going over a speed bump or the something like that? Because a few months ago the shop broke my original shifter and replaced mine after I came to pick it up for a different fix (I was kinda pissed that when I came to pick up my Expy after having them work on a starter issue for 2 weeks that the OD end cap on the shifter was ripped off and hanging by the wires, as if I wouldn't notice). That being said, they didn't replace mine with an OEM part but an aftermarket one and I've noticed that when I put it in drive the shifter wobbles a bit after going over a bump like it could slide into 1st... I'm unsure if this is the same issue that you had but I just wanted to ask for clarification. Great post by the way.
Jonnyrocket
Jonnyrocket
Phoenix Arizona
Sorry to hear they broke your OD switch. The loose I was dealing with was pretty dramatic. Like stirring a pot of soup with a wooden spoon type of loose. Crazy sloppy loose. If yours feels different than it did before they changed the shift lever it wouldn't hurt to remove the clamshell plastic cover and have a look see on the installation. You'll be able to see the entire shift tube while you shift it to see if there is movement. The bottom cover unscrews. To remove the top you'll have to unscrew the tilt handle and ignition switch. To remove the switch turn it to the accessory position then push up on a small pin from the bottom that holds the switch in place. Pull out on the complete ignition switch assembly. I cleaned mine and hit it with some dry lube on re-installation.
LarryM50
El Paso, TX
How did you remove the lower plastic piece to change the transmission shifter cable bracket? Mines is broken as well, but I cannot figure out how to remove the lower plastic piece. I was able to get a picture of it by sticking my camera phone under the dash. 20210818_133207.jpg
kapios
