Loosing VSS signal causing speedometer non-op and shifting issues
exponic
Chico, CA
I have a 1998 Expedition Eddie Bauer with a 5.4l. The speedometer went out while I was on my way home from school and the transmission just wants to stay in first gear, check engine light came on the next day. So I've had to put it 2 on the gear selector so it will switch gears if I must drive it a short distance. When it is cold ambient temperature and a cold start, the speedometer will work for a couple of minutes and transmission shifts fine ( because it is receiving the speed signal) and then speedometer will decrease in speed slowly till it quits working. While it is starting to not work, if I let off the gas, the speedometer will raise in speed.
I scanned the computer and am getting a P0500, P0501, and P1500 all VSS codes. When cold, the scan tool data gives a good speed signal but will decrease just like the speedometer and voltage going to the PCM. I have torn into the transfer case and checked to see if the drive gear for the VSS is missing teeth/loose, and even replaced it just because. I have tested the VSS coming off of the transfer case and am getting a good signal (increasing a/c voltage at higher speeds) at ALL times. I tested the signal going to the PCM and when cold, it gets a good signal and then as it warms up the A/C voltage starts to decrease until it goes to nothing. I also tested the voltage going to the speed control servo/amplifier and the same result as the PCM, good when cold then quits when warmed up. I have replaced the GEM because I read about a TSB about water getting into the module from a leaky windshield and still nothing.
So I guess I'm running out of ideas and wondering if anyone has any insight or had an issue such as this before, maybe where a connector or ground has problems causing the signal to be lost or a known place where wires could have rubbed/pinched. I haven't noticed any other electrical issues or weird symptoms going on.
