I guess the short of it is, that this A/C system has history. I'll try and walk you through the relevant things that happened recently that leads to where I am at with it. I feel like this is a solvable problem, but I just dont know where to turn now.
1 - Replaced entire A/C system 2 years ago (compressor, condenser, dryer, expansion valve(rear AC), orifice tube, monifold lines.
2 - Compressor started to fail twice(not enough oil was installed). Refunded and bought a Four Seasons that I just put in with a new Dryer, orifice tube, and compressor.
3 - Pulled vacuum and held -30 on the gauge for over an hour. Appeared to be all tight.
4 - Pulled over an hour worth of vacuum after that to clear out all lines or air and water
5 - filled with 62oz of freon and a total of 11oz of oil
6 - Running perfectly, blowing cold, drove about 5 miles, blew great.
7 - Parked in the driveway to clean out the garage. Sat for about 2 hours
8 - Started it up and turned on the AC and freon started blowing out between where the manifold lines attached to the compressor.
9 - Every time I turn the AC on now, it blows freon out from that location
10 - Checked the torque on the bolt for the manifold hoses to the compressor and it is perfect
Not sure what to do. It ran perfectly fine until I turned off the car and let it sit. I did all my validations prior to filling with freon and it was perfect. Now what...
