Mercon v vs lv in transmission
spsfrank98
US
I heard mercon lv is backwards compatible for mercon v. Has anyone used mercon lv in there transmissions? Is it a lighter weight compared to mercon v
Sent from my SM-N960U using Tapatalk
thesavo
Schenectady, NY
No. LV is not compatible is Mercon V. This is straight from Ford
Here is an Automatic Transmission Fluid Chart
Sent from my SM-N975U using Tapatalk
S
spsfrank98
US
Thank you for the replies I will read up on it.
Mercon LV destroyed several transmissions that called for SP due to lazy dealers when LV came out and they wanted to use it in everything. Don’t use LV in your trans if it calls for V.
M Bennett
