Message Center "Greeking Out"
darmahsd
Wilton, NY
A search reveals only some kind of soldering issue behind the instrument cluster board. I have an '05 with redesigned cluster. While driving the other day,
led display changed to random patterns of lines (Greeking).
Pressing button to change mode didn't help. Parked the truck for a few days.
Started it up on the driveway this morning (20° up here) and
got the display back. Can't trust for how long. I was going to
do a hard boot by disconnecting the battery for awhile. Will
try if and when I loose the display again. I'd like to hear from
anyone who has or might be dealing with this problem.
Thanks,
Stephen
D
darmahsd
Wilton, NY
Nobody? Guess not. Hasn't happened since. Back to normal.
Another weird quirk, I guess.
Newport News, VA
get ur alt tested if it is still the original alt...its about time for it to go...this was the first sign when mine went out...my diodes were failing and i had 2wks before i was deploying and had planned to change when i got back...alt had diff plans and only lasted about 5 more days...
D
darmahsd
Wilton, NY
Original alternator, with 74k. Gauge shows it's charging, but I'll check on that.
Thanks,
Stephen
