grdsman
Colorado Springs
Yeah they are all good. Checked them out. But im only getting 15in vacuum from the brake booster line that the iwe pulls from. Should be 20. Im going to take everything off that im comfortable with to see if it's loose. Or cracked. If yall have a diagram of this operation that would be awesome. It's right up against the firewall and looks to be a pain.
Sent from my SM-G965U using Tapatalk
Did you take the line off after the solenoid, where it begins its trip down to the IWEs and test it from there with just a hand pump tester? (with the engine off). This will test the actual IWEs and whether they are holding. Your description sounds like you are testing the actual vacuum being generated by the vacuum pump on the engine.
Mike
D
David Stevenson
Colorado springs
Yes I hooked the hand pump directly to the hub. It held vacuum. I am thinking that maybe the booster line is loose on the manifold and causing the lower than normal vacuum.
D
David Stevenson
Colorado springs
I get the new lines tomorrow. Also I didn't think about it but the boots around the check valve and solenoid are pretty worn out so it might just be those. Or the boots that go over the hub. Could've been that my vacuum fit better haha. Fingers crossed. I appreciate everyone's input.
D
David Stevenson
Colorado springs
Just an fyi at idle 15 to 17 is a normal vacuum at high elevation from the brake booster line. Im at 6500 ft. One of the techs here informed me.
D
David Stevenson
Colorado springs
So just got my new iwe vacuum tubes harness but the noise has completely gone away.... for now. My question is, say there is a connection issue (electrical short) to the solenoid would the solenoid lose vacuum?
D
David Stevenson
Colorado springs
Update. I installed a new motorcraft check valve and the grinding went away.... for a whole. As soon as the temp dropped I noticed it again but not near as much. Has anyone tried putting a second check valve in the hose assemble coming from the brake booster. Or could this cause problems?
grdsman
Colorado Springs
Yep, I did that on an F-150 as a fail safe. It won’t cause any problems. If it persists, it’s not the valve.
D
David Stevenson
Colorado springs
Okay lol. Back to it. Started doing it again
New solenoid, new check valve, new lines. Did a drive test with the guage hooked directly to the iwe vacuum and no loss of vacuum while driving or under load. The IWE at the hub held vacuum while parked. No way to check it while driving and I don't want to mess up my new harness. Could the iwes lose vacuum while driving intermittently or will it always be leaking? Bc the hand pump showed no leak anywhere. It's definitely the actuators cause it goes away as soon as I put it in 4wd. Looks like a fairly easy job and I've already replaced everything. Just want to get a little advisement.
aagitch
Paris, KY
I may have overlooked it in this thread but have you replaced the IWE's? That seems like the only other thing it could be.
D
David Stevenson
Colorado springs
I have not. I haven't yet because it held vacuum during the hand pump test. Held 20lb of vacuum for 20 min. But I guess going over bumps or under load it randomly loses its seal. Going to hopefully get them done this weekend.
grdsman
Colorado Springs
Did you replace them via Ford Tech Makuloco instructions? FTM has saved me some dollas!
No, but the process is pretty straight forward. If you’ve done front shocks, you’ve almost done IWEs.
D
David Stevenson
Colorado springs
Alright. Got them in. Easy work 2 hr job. I think getting the old vacuum lines switched out with the new ones was more difficult lol. Mechanic wanted 800 dollars. Gtfoh..... noise is gone for now. Knock on wood... thanks again.
07navi
Mt.Shasta California
Just as I thought, it's a lazy mans fix, it causes more part wear and worse gas mileage. When I had my Excursion they were leaving the hubs manually locked all winter which wore the expensive seals out, cause worse MPGs etc...………...not for me. Locking the cam phaser is a bad idea also but that's another program.
