miss fire
laylow8111
utah
2000 5.4 miss fire after replacing cylinder head. replaced coil packs but keeps coming up with 1 and 2 cylinders coil pack.
Bedrck47
Elizebethtown, PA
You made 3 different post all saying the same You only need to make one post as all post can be read by everyone.
Re check your wiring connectors. Make sure they are clean and tight.
Hampton, VA
Pick 1 thread to keep and delete all others...only need 1 thread
Mr. 10K
Hampton, VA
It doesn't increase ur chances of getting it address
Mr. 10K
Bedrck47
Elizebethtown, PA
Also check to make sure you didn't cross the connectors and put them on the wrong coil or injector
The color code is as follows
# 1 coil Rd/Lg and Lg/Wh
# 2 coil Rd/Lg and Pk/Wh
Injectors
# 1 Rd and Tn
# 2 Rd and Wh
