More TPMS (tire pressure monitor sensors) info
762mm
Quebec, Canada
As for the "magic" tires I used, my first set were Yokohama Geolandars. I did 12 years with them as my summer set and they were really worn by the time I replaced them. The thread was cracked and you could see the belting underneath, lol. I don't remember putting air in them more than once or maybe twice in all this time. I finally changed them for a set of Goodyear Wranglers and drove on those for the remainder of owning the truck. The last guy to put air in those Goodyears was the guy who installed them... on the day he installed them.
My original winter set were Michelin X-Ice. I bought them used from a guy who had them on a Ranger and his transmission blew up, sometime in 2007 or 2008. They came on original Ford steel rims and I did 10 years on those. I don't think I ever put air in them, just checked them every other year to make sure they were at 32-33 PSI, same pressure as my summer set. I finally replaced them with a set of used BF Goodrich (I forget the model), as the thread on them was getting real skinny. I never put any air in the BF Goodrich either, for the last 2 years of owning the truck.
Fun fact : besides my original Yokohamas, I never bought a new set of tires for this truck. They were all used (but in good shape) tires I got off internet classifieds in my area. I typically spent $200-300 for a set of 4 tires with 80+% of life left in them. My only condition was to buy quality brands, with researching reviews on the makes and models online prior to buying a used set.
bobmbx
[emoji23][emoji1787][emoji23][emoji1787][emoji23][emoji1787]
I think you are living in the good old days.
ALL tires, and I mean ALL tires lose air over time, just sitting, and it has ZERO to do with the seal, quality of the tire, or who the Rim is made by.
Just like making whiskey. The angels get their share the same way.
Lynnii2
Navy
San Diego, CA
I stuck my large pressurized tube with 4 sensors in it under the gas entry pipe and zip tied it in but when one of the used sensors batteries goes bad I will get about a foot long piece of abs pipe that is just big enough for the sensors to fit. Next time I will put a sensor on top of each tire and program them to the computer like that and then stick them in the foot long pipe. I didn't separate them enough when I programed them with the $15 little tool and they don't need to be under pressure to do it. Find the part # for your truck sensors which fit many vehicles to be safe. Most Fords take a 315 MHZ one and some later ones need to spin to work (mostly G.M.) so won't work here, and some have advanced features so just go by the part number. The pressurizing can be an issue also if you try to go with too small of a plastic pipe. The 2007 through 2011 Expeditions take the rectangular blue or black sensors that go in the bands that go around the wheel and not the type attached to the valve stem.
https://www.shoptpms.com/2010_Ford_Expedition_TPMS_s/3769.htm
