07navi
I stuck my large pressurized tube with 4 sensors in it under the gas entry pipe and zip tied it in but when one of the used sensors batteries goes bad I will get about a foot long piece of abs pipe that is just big enough for the sensors to fit. Next time I will put a sensor on top of each tire and program them to the computer like that and then stick them in the foot long pipe. I didn't separate them enough when I programed them with the $15 little tool and they don't need to be under pressure to do it. Find the part # for your truck sensors which fit many vehicles to be safe. Most Fords take a 315 MHZ one and some later ones need to spin to work (mostly G.M.) so won't work here, and some have advanced features so just go by the part number. The pressurizing can be an issue also if you try to go with too small of a plastic pipe. The 2007 through 2011 Expeditions take the rectangular blue or black sensors that go in the bands that go around the wheel and not the type attached to the valve stem.
