Multiple Radiator replacements
Status
Not open for further replies.
C
case2001
Georgia
Not sure if the pressure in the system was tested with the system running. I replaced the pressure cap when I replaced the radiator in the spring with a brand new one.
C
case2001
Georgia
I think I am going to drive is a bit and pull all the shroud off and run it to find exactly where it is leaking.
Temple, Georgia
I think the system pressure is at 16psi. Anything above it while running would indicate a possible engine problem.
The pressure increases once the engine is shut off, they should see what it rises to then also.
C
case2001
Georgia
Your right the pressure cap is 16 psi. I don't understand how it could be over pressurizing yet have leaks occurring at the same area of each new radiator. If it is pressure wouldn't it be differing failure points in the coolant system?
Temple, Georgia
You would think that it would leak at various points unless one China manufacturer is making the radiators under different brand names. Or there is a design flaw and just happens to be the weakest point.
Look at the fan shroud to see if the fan blade has been rubbing against it. If it has it may mean a motor mount is shot.
What kind of coolant are you using? Some are very unfriendly compared to the old green coolant.
Temple, Georgia
That rules out a coolant issue then...
Check the coolant drain knob also - they usually have a chitty o-ring that fails just by looking at it.
C
case2001
Georgia
Ok new radiator in. Replaced all mounts. The old ones didn't break when removed but they were pretty hard. Leak was up high near radiator inlet from block/thermostat at seam. One thing I did notice was the side skirting that protects the condenser and radiator was rolled in on both sides in so the seams were covered and not getting any air flow. Not sure if that makes any difference. Will keep thread up to date
C
case2001
Georgia
Ok no problems so far with the new radiator and the new mounts. I realized when I put this one that I had filled the first one incorrectly. On the first one I filled the degas bottle all the way and then kept squeezing the upper hose drawing more fluid into the system. Instead of simply filling the degas bottle to the full cold mark and then running it with the degas bottle open until at normal operating temperature. I am not sure if that makes any difference though.
I bought a Mitty Vac and checked my system for leaks cold and there are none cold. The system holds pressure. In fact when, I feel the upper hose with the Mity Vac pressuring the system to 13lbs, I know that my system is not even getting to more to 13lbs when driving on the interstate because the upper hose is not as firm.
In the morning I am going to start the truck with the Mitty Vac in place to watch pressure rise.
I rechecked for exhaust gasses in the radiator system with the engine warm and running. It was negative again.
The engine never ran or runs hot. Does not lose antifreeze. Is strong. I guess it is looking more like it was the rubber mounts binding up. I do notice the radiator is more centered in the oval grommets on the top..
Thanks for everyones help. Last radiator failed in 6 months, so I am 2 months in. We will see.
C
case2001
Georgia
Ok checked with Mity Vac. Needle rock solid with engine running even increased rpm to 2500. So that's good news I guess.
C
case2001
Georgia
Ok. Looks like the leak is back. Same location. Passenger side. I have to think it's something physically placing stress on the radiator. Help??
98EXPnSRQ
Sarasota, FL
It sure sounds like it. Maybe the mounting pads are not aligned flat and that is putting some stress on the radiator when it is tightened down. Has this truck been in an accident in the front end that would knock things out of spec?
C
case2001
Georgia
No accidents. I have had it for 16 years. But I would agree. Occurring in the same place repeatedly, would seem to indicate external stress.
C
case2001
Georgia
It is really firm. I can move the radiator about 1/16 of an inch if I really pull on it. But very little. I am wondering if that could be the issue. I am thinking about loosing the mounts a little to see if that changes anything. I don't see how it would hurt.
Temple, Georgia
Just for sheets and giggles, what type of clamp are you using on the upper radiator hose - factory spring or screw type?
How old is the upper hose?
Have you pressure tested the system yourself?
C
case2001
Georgia
Screw type clamp upper. Pressure tested it with my Mitty vac both cold and hot.
C
case2001
Georgia
Oh and the upper house is at least 6 years old.
C
case2001
Georgia
Ok going to change the radiator this weekend. Again checked for electrolysis 0.02 volts both with ignition on and off and with engine running. Also check AC and 0.01 volts.
I am considering changing antifreeze to Zerex brand instead of Prestone. Any thoughts?
Oh and my front heater core is clogged so I am going to change it as well. I thought this would be a good time to change as the system will be complete flushed.
Status
