Snagglefoot
Hey guys, thanks for the help with my last problem.
I have a new issue and am having a hard time pinpointing the exact trouble piece.
First, it is a squeak. The squeak only happens when the engine warms up. When it decides to squeak it is very consistent with its timing. It starts to squeak and then the sound goes away for about 20-30 seconds and then comes back. sometimes louder then before. I have sprayed liquid wrench behind the serpentine belt of some of the components on the engine and the sound did go away for about half a day. I believe the sound is coming from the passenger side of the engine compartment. I have not changed the tensioner or the belt yet because it doesn't sound like that kind of squeal. And the belt doesn't squeal on start up. The coolant temperature is fine, I don't know if it is the pump or not though. Sometimes at speed on the highway I can hear a quiet consistent squeal ever once in a while under the sound of the engine. But, goes away as I slow down and stop, then picks up again as I am sitting at the stop, then goes away as I start moving again. I would be able to tell if it was the belt, I know what that sounds like but this has me lost...Thanks guys for any help you can give. "Expedition's Rule"
Sincerely,
Nathan Jensen
Sincerely,
Nathan Jensen
