My turn now for Cam phaser replacement on my 2019, need your feedback?
armoredsaint
Ohio
So I have almost 25k miles on it, got it new - they did the reprogramming about 2 months and it started to rattle at cold start-up only about two weeks ago.
But I did an experiment and used 93 octane instead of 87 for the past 500 miles and it doesn't rattle - coincidence?
The dealer said parts can take a few months as I am on the waiting list now, not sure how true it is either and it's a 10-12 hour job and will provide a loaner car.
Sorry, I haven't been keeping up with the other threads on the cam phasers, but does this sound typical?
FlyBry
Dallas, TX
Change back to 87, see if it returns? If it does, change back to 93, and let us know the results.
Shaggy
Administrator Moderator
Arizona
Yeah, like @Bmac1955 said, i dont think changing octane would stop the cam phaser rattle for long. I just got the cam phasers replaced on my truck and so far its been great. Just stay on that list and get them replaced under their warranty.
armoredsaint
armoredsaint
Ohio
That's my plan to finish or nearly finish the 93 and switch over to 87 again and see what happens, i know it's weird and i can't explain it either.
lurch
Boulder, CO
I only put 91 in mine, 93 is not available in CO, and it still developed the rattle.
fordman2021
Georgia
Mine developed the rattle around 37,000. I had the reprogramming done twice and then the complete replacement. It took a month to get it repaired due to the labor backlog at the dealership. Parts weren’t an issue in April when I took mine in.
My check engine light was on before I got home. It was running rough and ran like it was choking out at low speeds. I guess they don’t test drive repaired vehicles? I took it back and they had it another three weeks. They said they had to contact Ford Engineers as they couldn’t figure out the issue. My $10 code reader from Amazon pointed to the VCT Solenoid. After three weeks, they told me it was a bad VCT solenoid and I got it back.
Luckily I had a loaner on both occasions but I was without my car for almost two months. Your mileage may vary
DavidCola
South Carolina
I had the phaser repair at 63k in February on my 2019. I am now at 72K with no issues. it took the dealer 3 days to complete.
FryerTime
Hopkinton, MA
Mine needed it with around 45k miles. Took a few weeks to get the parts in. I dropped it off Tuesday am and it was done Friday afternoon under warranty. We'll see how the new design holds up.
bryz_expy
Denver, CO
Jan 22 - 35k miles my 2019 went into limp mode but reset after a restart. so I dropped off just to get it reviewed. They said it skipped timing- Reprogrammed, Timing chains and cam phasers replaced all in same visit. They reprogrammed and kept it over night and could still hear it on cold startup. Took 3 days total. Got it back and a week later coincidentally got a CEL for a catalytic converter inefficiency. Able to keep driving but waited 2 months for parts. Both cats were replaced. Running fine, another coincidence that my accelerator pedal failed which may been the original reason for limp mode I suspect. Everything has been fine, fingers crossed.
Randolph
SoCal
I wondered what this issue was with the noise at start up for us. Our 2019 has about 80,000 miles on it. We bought it used as a certified vehicle from a dealer in Riverside California but I believe have still warranty up to 100,000 miles. Where was your dealer and was your repair covered under warranty? Anyone else that has dealt with this was it also covered under warranty? Thanks.
techdude99
US
...But I did an experiment and used 93 octane instead of 87 for the past 500 miles and it doesn't rattle - coincidence?...
It's not just you. I ran 93 for 20k miles on my brand new '19 Platinum and never had an issue. Switched to 87 for 3000 miles and the truck bogged, motor was louder idle, and gas mileage decreased.
Switched back to 93 for the last 2k miles and everything is back to normal. The truck has 25k miles. Took it to the local Ford store this morning for the PCM updates. We'll see what happens in the next 10k miles...
03Cobra
NC
I have gone to the CO and MT and back to NC twice now in my 2021 and 87 gets a couple of miles per gallon worse for me its been 2-4 mpg less than 93. I have tested it many times I mostly run 93 you get the best gas milage on it with 93. Going to FL soon from NC and will be using 93 to get the max range I can before having to fill up again.
Bmanxx13
Arizona
I run 91 in my '18 and developed the rattle around 35-37k miles. Had the cam phasers replaced under the powertrain warranty soon after the rattle developed. Ford had my expy for about 3 days -- including diagnosis. I'm at about 68k miles now and all has been good so far...
