Shaun M Johnson
Here's my scenario:
I have a 1997 Ford Expedition XLT 5.4L SOHC VIN "L"
I pulled the engine for an overhaul but then engine was no good. So I bought a new engine.
The new engine is from a 98 Expedition and nearly everything is identical except the intake systems; intake manifold, throttle body, vacuum routing, HVAC heater hose assembly (tube to back of water pump).
The 98's HVAC tube has an additional 1/4" outlet type that the 97 does not have. Also, the 98's throttle body has an additional 1/4" inlet tube and two additional vacuum lines connected on the passenger side (right side) of the throttle body. The 97 does not.
My questions are....
1. Will the 98's system work with my computer in my 97 Expedition1?
2. Are there any performance or efficiency or mechanical/maintenance perks between the two intake systems?
3. If I have to use the 97's intake system because of my 97 computer, will the 97's intake even work on the 98's block and cylinder heads.
4. Do you have a 98 Expedition with the same setup as my new 98 engine's intake?
Additional Note: I have rebuilt the 98 engine. New paint, pretty much everything.
I will comment the images so they are separated to make it easy on everyone.
