Need help DRL
juan214
Stoughton, MA.
I'm trying to get the DRLs working on my 1999 Expy. Found the loop under the dash panel on the passenger side. Pulled it and plugged in the factory DRL module and mounted in its factory location. Went to drivers front to pull the cap off the harness to install the resistor. Found the harness unplugged it from a black box. Went to plug in the resistor and the plug only had one terminal and wire leading to it. It should have two, not sure what this harness was plugged into, but it was in the location the resistor should be mounted. What am I missing and what's my next step. Do I need to find something else.
Temple, Georgia
Check these and see if you have the correct connector for the resistor.
  • 097-001.pdf
  • 097-002.pdf
