Hi Everyone im new and have a problem with my 99 Ford expedition everything was running fine until one day i was sitting in the parking lot with truck running and i shut it off when i went to start it it started and when i put it in gear it died i found the fuse for the fuel pump blown i replaced it and as soon as i put it in gear it blew again so i figured my fuel pump was bad so i went and replaced the fuel pump and after i got it done i fired it up and it will sit there and idle with no problem until you put it in gear it blows the fuel pump fuse any ideas would be greatly appreciated cause this is my only vehicle i have and i need to get to work I have been looking and found this thing called fuel pump driver module? now is there such a thing on a 99 expo and if so where is it located,
thanks eveyone
thanks eveyone
