New head unit, now sub "thumps" when turning on...
bgrattan
Oregon
I just put a Pioneer AVH-1440NEX head unit in my '06 Limited to get CarPlay and a backup camera. Most things work well, but a few seconds after I turn the key on (and the head unit powers up) the sub "thumps" once--kind of like when you plug something into an amp that is already on. I'm assuming this has to do with the timing of the sub amp turning on. I used the "system control" wire (blue/white) going to what I believe is the amp's "power on" signal.
If I connect the amp's "power on" to the switched +12V instead, so that it should turn on as soon as I turn the key on, do you think I would get rid of the "thump?"
It didn't have this problem with the stock head unit.
Ron1978
Ms
Do not use loudness on the radio, leave it off, I just installed a whole system in my f250 and the amp instruction says do not use loudness setting in radio. See if it helps
Well I'm going to throw my 2cents in here. Whenever I hooked up an amp, whether main or sub, the hot lead, yellow usually, goes straight to the positive terminal of battery. The turn on/off wire goes to a switched 12 volt source. Is that the way you wired it? Sounds like you did, but just checking. Amplifier hots should always go straight to the battery, with a 30-80 amp fuse in between depending on wattage.
Ron1978
Ms
This is very correct, I run from battery 8" from it a 100 amp fuse then straight to the amp, then blue remote wire to amp from radio, make sure you have a good ground with no paint between the connection, Grounding is key to a strong setup
B
bgrattan
Oregon
Thanks guys. I'll check the power connection, it may be going to the switched line.
Aspen03
Indianapolis
You can use an AXXESS AX-CAM6V or a couple of 1k ohm resistors to step voltage down to eliminate it. The part from axxess works great
johnboneske
Ohio
The thump is caused as Hamfisted said... The factory amp is 5v, and an aftermarket head unit is 12v. They make an adapter for it too. For around $15 on Amazon
