New suspension
99 Expy
Laramie, WY
Hey guys, I am in need of some new suspension. My first priority is the shocks. I am thinking if Rancho RS5000. What shocks have you guys had the best luck with? I also need to replace all of the ball joints and control arm bushings. Is there anybody out there that sells these all as one kit? I am looking for a set for a decent price, but not the most expensive ones since I still have to buy my new BFG ATs before I head of to school.
Thanks for your input
SOLISIMO
Ft. Lauderdale
I read some good reviews for the Bilsteins and the Ranchos. I dont think you can go wrong with either. Btw what is the purpose of your truck? Is is lifted or leveled?
nvycrmn
Springville, IA
im runnin the rancho's on my expy and they work great. as for getting new balljoints and whatnot, if you are gonna do the work yourself, just pick the parts up from autozone or parts plus (or any shop you like). im from iowa too and if your town is anything like mine, there is always a country boy around that can help ya.
99 Expy
99 Expy
Laramie, WY
Thanks guys, that's pretty much what i was thinking. I think i'm going to buy the rs 5000s this weekend and ball joints with any extra money. I would like to make the truck purposely for off roading, but unfortunately I have to pay for school, and I have to drive 700 miles one way to school, so the stock ride is a little cheaper and more suitable for now. If I still have the truck when these parts need replacement again, I will be done with school and be able to make a nice off road machine :D
smo0othride
San Diego, CA
Try to find some polyurethane bushings, they will improve the handling and last longer. I have bilstein HD shocks and they're pretty good, I've never had the rancho's or anything other then stock so I don't have much to compare to.
KWT2000
NINE MILE FALLS
for shocks im running trailmaster ssv have had good luck with them on other vehicles... when i did my ball joints and inner tie rod ends i used MOOG products if you look at the stock component and the moog side by side the quality and strength of the moog over stock is night and day... energy suspension makes poly control arm bushings and the handling difference is huge. good luck
smo0othride
San Diego, CA
I'm still jealous they don't make poly bushings for the 03 model... it's the only thing missing in my suspension upgrade.
99 Expy
99 Expy
Laramie, WY
Hey guys, I ended up buying the rs5000s from https://4wheelonline.com/ last weekend and had them shipped to my door for $165 which is about $50 cheaper than i was quoted at my local parts stores. I got them Friday and put them on this afternoon.
I am going to get a set of the MOOG ball joints next weekend and I am also going to get poly bushings for everything. Energy suspension has a master kit that runs around $350. Anybody using these now? Are there any other brands you would recommend?
Thanks
tonydiv
technical advisor
Middle River, MD
Go with the Energy. Just don't skimp on the lube when installing the bushings. If you do, your truck will squeek like crazy.
If you order from energysusupensionparts.com they include extra lube for free.
KWT2000
NINE MILE FALLS
energy all the way im running the upper and lower control arm bushings and sway bar bushings and links they work well... like mentioned above dont skimp on the lube
99 Expy
99 Expy
Laramie, WY
It's been awile guys, but I finally got it done. I replaced every bushing on my truck. I used energy suspension on all of them but the front control arms because when I did the ball joints, the upper control arm came with them so I didn't want to spend the extra money to take out the ones already in there, so both upper and lower front control arms have moog bushings. Everything went ok for installation except that the sleeves in the rear control arm bushings had a 9/16 hole, but they were supposed to be 5/8 so the bolt can fit. Anybody else had this problem?
