No abs light on dash
tonydiv
technical advisor
Middle River, MD
I just noticed that when I turn the key to the on position and all the dash lights test themselves, that I don't seem to have an abs light. I do have the regular "brake" light, is there a seperate one for abs?
Could someone with a 98 that has a mechanical odometer check for me?
I guess that I'll also have to check to see if the previous owner decided to pull the fuse.
trdragons44
nj
mine does its right around the 6k rpm and btw i have a 97
trdragons44
nj
i changed the image location for ya should be able so see it now
tonydiv
tonydiv
technical advisor
Middle River, MD
Well there is a spot for that light on my dash but it never goes on.
Both of the abs fuses are fine, so it seems like someone, somehow disabled the abs system another way. It may just be for the better since the oversized tires would probably make the system act funny any way.
Do any of you other big tire guys have abs performance issues? I'm just not sure if I should make this a priority to repair. Especially since there are sooo many other things that I'd like to do to the truck.
JUST4FUN
Admin
Moderator Administrator
Il
the light could be burnt out
ELVATO
Orlando, FL
That's what I'm thinking.
Not sure if it'll work on your Expy, but if you have digital readout for the odometer, it should. I think you hold down the reset peg, then turn the key (while still holding the peg down) to the RUN position. The cluster enters a diagnostic mode. You push one of the pegs (I think the reset one) to scroll through the options. One of them (maybe the second one?) lights up all the bulbs in the cluster.
As a side note, there's some cool options there. You can have, for example, the tach show up where the milage is. Granted, you have to redo the procedure everytime you start up the truck, plus, it resets your tripometer.
tonydiv
tonydiv
technical advisor
Middle River, MD
Unfortunately I have the old style odo.
I didn't thing it was a big deal until I found out (too late) that my Edge programmer can't adjust for tire size without the digital odo.
