No brake lights, turn signal or flashers.
bdot0621
texas
I have a 2015 EL XLT and has been giving me hell with at first intermittent brake/turn/flash…now they have completely gone out. Bulbs are fine and even turn on the other filament that runs the rear lights in the back but the other filament never illuminates on both sides. Front turn and flashers work fine. I’m thinking the fets that control these lights are bad in the bcm. Can anybody help me with troubleshooting?
Hamfisted
Ft Lauderdale
I don't know if you have it already but here's the wiring diagram for the exterior lighting on the 2015-2017 Expy's. Has the Expy ever been wrecked in the backend ? I think you can see the BCM functions in ForScan on a laptop using the appropriate HS/MS OBDII adapter. Should show up on the MS bus, so put the adapter's switch in the MS position if it has one.
  • 2015 Expy Ext Lamp Circuit.pdf
B
bdot0621
texas
Man thank you! I’ve been dealing with this for a couple weeks and really need to get this resolved. I will take a good look tomorrow. Give u an update
Fastcar
Army
FL
If you have the plug for trailer lights it might be worthwhile to check there
B
bdot0621
texas
All chassis grounds are corrosive free and are not frayed. Checked the harness and plug for trailer lights.
I’ve been looking at the diagram, could it be the FET in the junction box that went out? I’ve actually bought a bcm/junction box and replaced it. It’s used but the truck doesn’t start when it’s connected and I wanted to know if it needs to be programmed first. Thanks for any help
Fastcar
Army
FL
Never used the trailer lights. How would I verify that?
You should have 1 or 2 receptacles to plug into. The wiring coming into them from the back may be at fault. You use a meter to determine if the signal is coming through the receptacle.
B
bdot0621
texas
Checked the end receptacle and I was able to get voltage on the brake pin reading 12.07v also the same for hazards and turn signal. Also tested rear brake, flasher, and hazard ends and was able to get a 10-12v on all pins when I triggered the function. At this point I’m almost positive it’s the smart junction box/bcm. I have one but the damn dealership won’t program it without having my truck stay with them and they are behind and will have to keep my truck for 5-7 days. Smh
1970Maverick
orlando, fl
I don't understand your sentence:
"Bulbs are fine and even turn on the other filament that runs the rear lights in the back but the other filament never illuminates on both sides."
What do you mean by OTHER filament? You use that term twice in one sentence.
Just my guess but I think you have a loose or missing ground.
B
bdot0621
texas
There are 2 filaments in one bulb. One filament is for the brakes/turn signal/haz….the other filament is for taillights
