No Heat at idle
Eightiesrock80
Eightiesrock80
Frankfort, IL
The out heatercore hose is pretty cool compared to the in its hot at idle but that can change could be air or could be clogged I’m looseing my mind lol
Jarheadmatt
Fullerton, CA
is the heater valve vacuum operated? I know you said the HVAC system is auto, but if the valve is vacuum operated you may have a vac issue. Another thing could be the blend door motor.
Eightiesrock80
Eightiesrock80
Frankfort, IL
When I make the heat go from hot to cold when the heat is actually working it goes back-and-forth so I believe the blend door is OK
Eightiesrock80
Eightiesrock80
Frankfort, IL
The vacuum line for the heater control valve doesn’t seem to do anything the heater control valve seems to always be open I did just noticed that one heater hose to the heater core is sometimes cold in the other one is hot so I’m thinking I need to unclog the heater core
Eightiesrock80
Eightiesrock80
Frankfort, IL
It’s so weird though Out of know where the heat will work good but When I stop it still will not be as hot but warm
99WhiteC5Coupe
Years ago I had problems with low heat on a Chevrolet I owned, that had a vacuum operated heater control valve.
The valve seemed to work - the lever would open and close. My father suggested I remove the valve and inspect the inside. I did and found that the “flap” that would block the coolant flow inside the valve was loose and not moving to the full-open position, although the vacuum operated lever would move back and forth. I replaced the valve and that cured my low heat issue.
If your valve is stuck open, it may have a partial blockage inside the valve - which is overcome when you increase the engine’s speed.
You may want to remove and inspect the valve. Good luck.
