No output to receive error codes
jacob shedd
san antonio
Hello all,
I'm a new at troubleshooting and went to autozone with my 2000 5.4L expedition to try and receive codes for a engine misfire and lo and behold it didn't register any codes. Also - i have never had a check engine light come on and i know for a fact i have multiple problems. What should be my first step in troubleshooting this problem. My first step i took was locating the corresponding fuse and could not figure out which fuse worked for the device. I am blind with this issue and do not know what the device or circuitry would be. Thank you. - jacob
Temple, Georgia
Welcome to the site.
Was their scan tool able to communicate with the pcm? Your other post implies it couldn't.
If it can't communicate with the pcm it cannot retrieve any stored codes.
J
jacob shedd
san antonio
The gentleman at autozone simply stated that he couldn't receive anything from my vehicles connection onto his device and recommended me checking the fuse
Temple, Georgia
Ok. See the sticky in the electrical section on how to check fuses. I prefer a test light here since it is faster than using a meter.
AZ may have the power distribution diagram online so that you can find the one for the dlc, if not I can load it later today. Make sure all fuses are good at this point - replace only as needed.
I've been in Temple @10 years and have seen a little growth over the years.
Bedrck47
Elizebethtown, PA
Welcome to the forum
It should be the fuse for the cig lighter Look in your owners manual for fuse location also if you don't have the owners manual you can download a copy at
owner.ford.com
