Not so Good Vibrations
whtbronco
whtbronco
Winchester, VA
Based on the chart below I bet my scanner is reading the EPC solenoid pressure and not actual line pressure. I just can't believe that if my trans pump was around 20% of the low side pressure that it could even grab a gear. The EPC pressures I saw are on the low side of this chart, but within the ranges, that makes more sense since I have no shifting issues.
kep5niner
Army
MO
Helluva quest to get this figured out! I can see how a shop would’ve tossed their hands in the air a while ago, and just tried to sell you a new $100k Expy instead of figuring out the problem.
Nice work! Stay at it!
whtbronco
whtbronco
Winchester, VA
Thanks kep5niner.
LOL, yeah and even a very reasonable shop would have probably cost me a fortune at this point. Course a lot of true mechanics would be better at troubleshooting than I am, and a lift would help tremendously. $100k for a light duty truck of any kind is just crazy to me. Maybe all my rambling will help someone else someday. It's already allowed me to go back and read what I did so I guess that's good.
We've driven 11 trips in the past 2 days and about 200 miles with no misfires so what caused that the other day is beyond me. We have had that occasionally though over the last 20yrs. It'll just misfire for 30-60 seconds at or shortly after startup, every now and then. Since I never found a cause I just chalk it up to computer/sensor issues. My wife commented today that the vibration felt the worst to her at 1000rpm and decreased as she went faster, and that it's very smooth at full throttle now following the transfer case swap.
whtbronco
whtbronco
Winchester, VA
I wasn't able to touch the truck over the weekend. This evening I decided to just check the engine accessories again since I didn't have very long. I popped the belt off, it's certainly smoother without the belt on it and low and behold my water pump is weeping a bit. I found a bit of coolant on the bottom of the steering rack. So that will get changed this weekend, got a Motorcraft pump on it's way. I also think the A/C compressor doesn't sound real good, not terrible though. However, correct if I'm wrong, but I don't think either of those would cause the vibration to get worse while coasting/decelerating. So there may be yet another issue. I'll do the water pump first and go from there.
whtbronco
whtbronco
Winchester, VA
The water pump has been replaced. I took the opportunity to flush the coolant out, it was on my list to do so now was the time. With the pump and thermostat out and then pulling the heater core hose from the intake it's pretty easy to get most of the coolant out of the block as well.
I really wish the 5.4 had an air bleed screw.
Certainly running a bit smoother, I just did a short test drive though so I'll know better after I go to work Monday.
After dealing with the removal of the fan again I am seriously thinking of putting in electric fans. It's is so freakin' hard to loosen the fan clutch from the water pump by myself. Even with a dedicated fan clutch tool set, it's a PITA. In fact I don't even try to use that clutch wrench, just the pulley wrench.
kep5niner
Army
MO
DO IT! Throw the Volant air intake on there while you’re at it. They do include a 15% military discount as well - it’s like they’re paying you at that point.
PM me if you’ve got any questions. You won’t regret it!
whtbronco
whtbronco
Winchester, VA
I'll keep the fans and intake on my list. That list got a good bit longer recently. One of the list additions is a trans pan gasket on my sons Ranger. It's dripping on the cat so that is right at the top of the list and will replaced tomorrow night. Next up for the Expedition is to cut out the rust in the trans cooler lines from the clip that holds them together at the bottom of the radiator. This was identified during the water pump replacement and appears to be fairly common, just as common is not being able to find the line that runs cooler to radiator. So I'll cut, flare and clamp in some trans hose.
The water pump replacement resulted in 2 things. It showed that I had both a high and low frequency vibration, I figured this might be the case. It resolved the high frequency vibration.
The low frequency vibration remains and is low rpm, certainly not engine rpm. What makes no sense is that it doesn't seem to get faster as speed increases it just becomes more pronounced. It begins at 32-33mph and continues to 80mph, haven't tried faster but it would be there. It's just barely noticeable under cruise power or heavy load, moderate under light power load and very pronounced when coasting. Dropping it into neutral doesn't help much. It's primarily noticeable in the seat and floor, course if I get on the brakes I can feel it in the pedal and the steering wheel. What's interesting and it might be just a mental issue, is that it seems I can feel it under braking down to ~25mph coasting it goes away when I get down to ~33mph. 25mph or below it's not noticeable and very smooth now. It does seem to be worse after 20 miles or so on the interstate, so heat is likely playing a part.
The salvage yard transfer case is now leaking at both output seals despite having new bearings and seals throughout. I can't help but wonder if the transfer case is the cause, it wasn't well cared for by the previous owner. So that's next on the vibration hunt since it's getting done anyway. I am going to put new bearings and seals in my original transfer case, hopefully this weekend. Then next weekend I'll swap them and we'll know.
whtbronco
whtbronco
Winchester, VA
The Ranger trans pan gasket has been replaced, the trans cooler hoses were leaking so they were replaced and I ordered an entire gasket kit for the engine. My goodness I was shocked, the valve covers and/or intake are leaking oil and it's covered both side of the block, the oil pan is leaking, the rear main seal has been leaking for a while. Thinking we'll pull the engine out to replace the seals, ugh.
The original transfer case for my Expedition now has new bearings and seals. What a difference between mine and the salvage yard unit. Mine was clean inside with nice red fluid, which I knew, the clutches look really good in comparison and had no pealing of the anodizing, and far less wear despite having 60K more miles on it. I don't think the fluid was changed much if ever in the salvage yard unit, so maintenance makes a difference. After I reassembled the salvage yard transfer case I thought it felt good, but the original one is so much better. Smoother, quieter, easier to turn. This bearing and seal kit had different bearings and that may be part of it. The other thing that surprised me is how easily the case went back together this time. I fought with the salvage yard unit to get it back together, this one just fell together quick and easy. Picks below for comparison.
I don't think the remaining vibration is the transfer case, but next weekend I'll swap the original back in and find out. With any luck I'll also get to repair the rusted trans cooler lines. The plan is to cut out the rusted part of the lines, bubble flare the ends and slip some hose on.
whtbronco
whtbronco
Winchester, VA
Not sure what I was thinking the other day when I noted that the vibration was present to 80mph, maybe it should have been 70mph. Anyway, today I pushed full throttle from 0-70mph and couldn't feel it at all until I backed off. It's present from 32-74mph, really starts to go away about 70mph. I think it just gets so fast I can't really feel it anymore. It means it's wheel speed related for sure though. Yesterday I had a 2 brief periods of no vibration at all which caught me off guard and I can't explain it.
I have basically decided that if the transfer case doesn't resolve it that I'm back to the beginning. Putting up on jack stands, checking suspension and running it up to speed while I climb around underneath listening and feeling.
whtbronco
whtbronco
Winchester, VA
The transfer case has been swapped again. I have not yet been for a test drive, probably be tomorrow.
Before the swap I spent some time looking for things are loose or had play in them. I found 1 thing, the support bracket for rear diff, aka torque arm. There's no real play from neutral to reverse, but neutral to drive there's like 1/8-3/16" so that's gotta be replaced. That said the factory part is not available and I have not found a new one on eBAY, Amazon or such. Below is what I found regarding a replacement. I think this will work so I'll probably take my chances on the 8L1Z part and hope it works out.
I'd try just a replacement bushing. I haven't yet found that either, but I'm still looking.
Torque arm assembly:
4L1Z-4612-AA (03-06 Expedition) all 4yrs of the Gen 2
5L1Z-4612-AA (05-06 Expedition) really just 2yrs of the Gen 2
8L1Z-4612-A replaces 5L1Z-4612-AA and 7L1Z-4612-A (07-17 Expedition) some places show this fits 05-17 Expeditions so why would this not fit the 03-04.
whtbronco
whtbronco
Winchester, VA
I found a thread where Hamfisted suggested part # 8L1Z-4612-A for a 2006. High probability that's correct, Mike always seems to be on point.
whtbronco
whtbronco
Winchester, VA
7L1Z-4B425-B is the bushing for the torque arm(8L1Z-4612-A). I'm not sure the bushing would fit the factory arm, but I am fairly confident the 8L1Z arm will fit the truck. So I've ordered the arm.
I also ordered a new Motorcraft fan clutch. Functionally it's working fine, but there's some play in it if I rock it and I have been wondering about it for quite some time. Sadly I just don't have time right now to swap to e-fan's
This might resolve some more of the vibration, how much we'll see.
I'll be getting a battery soon too.
whtbronco
whtbronco
Winchester, VA
To my surprise reinstalling my original transfer case with new bearings and seals did help to reduce vibration compared to the salvage yard transfer case that received the same treatment. Mine is in much better shape and felt smoother on the bench even. Maybe 40-50% less both under power and coast. Most notably when coasting from say 70mph it would start to vibrate some in the seat and floor, then if I hit the brakes to drop to 40mph for an exit ramp I could really feel it in the brake pedal. The brake pedal vibration is gone or mostly, it might just be in my head if it still exists. Once I get down to 35mph or less there's no wheel speed vibration.
Tasca has for the 2nd order in a row cancelled my order due to being out of stock, though they still show the part in stock, argh. This time for the rear diff torque arm, they show 26 in stock. My wife just went to local dealer and paid an extra $50, total $205 including the governor's share. They always charge MSRP or higher, but it'll be available tomorrow. I'll get that installed this weekend and see how much the new bushing holding the diff firmly helps.
Still have some engine speed vibration I'm tracking down. A new fan clutch has been installed, not sure that helped the engine speed vibration. It is certainly tighter. All I did was run it in the garage though.
Maybe someday I'll get all of the causes of the vibration figured out. I got most of this resolved a while back when I replaced the rear cv axles and hubs. Not all of it though and it clearly snowballed while it was being ignored until it just got to be too much for me tolerate any longer.
When I get done I'll compile a list of the things I replaced, adjusted etc...
whtbronco
whtbronco
Winchester, VA
The new water pump and fan clutch certainly made a noticeable difference in the engine vibration. There is still a bit more to track down, but I can only feel it when not moving. Below ~35mph this thing is really smooth going down the road now.
I got the rear diff torque arm/support bracket replaced today. Not sure that really needed to be done. The factory bushing is cut out on top and bottom to allow some movement, though it did only move up when shifted into Drive. I did not fire it up to test it. I can tell you one thing, the replacement was not painted, the factory one was. I cleaned the replacement and covered it in undercoating and then filled the front of it with RTV to help keep crap out of it, the factory had epoxy that closed the front.
Yes Ford and Tasca this does fit the 2004 Expedition, 8L1Z-4612-A. The only difference is that the replacement was not painted and had a solid bushing which I expect to hold it in place a little better.
whtbronco
whtbronco
Winchester, VA
I think I may have found the remaining engine vibration. There are some very intriguing clean'ish spots behind the harmonic damper. However, it looks like the rubber between the center section and pulley has moved. I was wondering if there might an issue with the damper, my other thoughts were the flex plate or torque converter. Of the 3 I sure hope it's damper. What do you think?
I know the front main seal is leaking, that'll get replaced soon maybe along with the damper. BTW, my son-in-law is 3D printing a seal installer for me. I did not want to pay $200+ for a front main seal installer.
The pics kinda suck, I'll try to get a better look and pic, it's hard to get in there right now
whtbronco
whtbronco
Winchester, VA
I went ahead and ordered a new OEM front main seal and damper.
Once again I am gonna be wishing I had e-fans since I have to remove the fan for the 3rd time this month.
whtbronco
whtbronco
Winchester, VA
Well the damper and seal arrived 5 days early somehow. So tomorrow I plan to take care of this. The seal installer my son-in-law 3D printed for me looks okay. I had expected it to be a bit wider, but I had no measurements. I just thought it would fit around the outer lip on the seal, but as you can see it will flatten the lip and push directly on it. Being a new seal it's quite pliable so I'm sure it'll be fine. Based on comparing the seal installer to the new damper it will fit perfectly over the crank shaft.
whtbronco
whtbronco
Winchester, VA
The front main seal and harmonic damper have been replaced. The seal appears to have resolved the oil leak. The damper didn't resolve the vibration, but it seems to have change the rpm ranges where it's vibrating in park/neutral. Of course it was inconsistent previously sometimes it just didn't seem to be there at all. I know when it did vibrate there was a spot a bit above idle and another just below 2000rpm. Now paying very close attention I noticed there is something tapping, like a light rod knock, at 1200-1300rpm now and then it vibrates from 1300-1400rpm and then calms down. I only listened from the drivers seat, maybe today I'll get under it and have someone hold it at 1200-1300rpm to try and isolate it.
The crankshaft bolt is too short to install the damper from start to finish. The seal installer worked fine though, I was able to tap the seal in with a hammer and then use the bolt for the last say 3/32" and it pulled it in.
A "you dummy moment":
I decided not to bother my wife to come start the engine while I kept an eye under the hood. Well that was a mistake. I had removed a trans line from the radiator so I could get the fan shroud out and I forgot to put it back in. Shot 1.5 quarts of ATF all over the place before I saw it and shut it off. My goodness what a dang mess. Took almost 2hrs to get it all cleaned up and re-filled.
whtbronco
whtbronco
Winchester, VA
Well this weekend it's time to get back under the truck, the vibration under power has increased a good bit again since the front main seal and damper were replaced. Sometimes it's worse than others and sometimes I can feel it in the brake pedal again. The inconsistency all the time is driving me nuts. I'm gonna pull the inspection plate on the trans and it sounds like there is some barely audible whining/humming in the rear at higher speeds. Could possibly just be tire noise, it's around 60-70mph.
The PCV grommet is leaking a bit, that'll get replaced tomorrow. Not a single store in town had one that would fit so I had the Ford dealer order a replacement, Only $9 anyway.
whtbronco
whtbronco
Winchester, VA
Well on the way home this evening the vibration felt more pronounced and I started thinking it was suspension. I took it up to 80mph twice and it definitely felt like suspension. Turns out the upper left rear ball joint bushing is loose. This makes sense as it was intermittent and varying in intensity. So now to get 4 new bushings(both uppers and both lowers), I wish I could just buy 4 new control arms as well from Ford.
PCV vacuum leak is fixed.
Just gotta keep nibbling away at this stuff.
