Not so Good Vibrations
whtbronco
whtbronco
Winchester, VA
I replaced the driver side upper rear control arm to knuckle bushing. Once the right bits and pieces are figured out it wasn't too bad. I used a rented ball joint press and receiver cup to press it out. I actually had to press the center out first since I was not able find anything that would clear the mounting flange of the bushing while being thin enough to fit inside the knuckle. This worked out okay since it kept me from separately taking it apart on the bench. I wanted to see how this thing really works and it is not what I thought, I mean it really is a ball joint. For install I used a bolt, 1/8" thick washers, nut and 33mm deep impact socket to push to install and a 1-1/2" socket to receive.
Something else that surprised me is that this is where the camber adjustment is, the control arm mounting holes are ovals. I was not expecting to need to get it aligned.
I drilled a 2x4 and pushed it onto a pair of lug studs to help support the knuckle. Here's a couple pics of the bushing/ball joint. I thought it was interesting, maybe some of you will as well. I'm wondering where the rest of the rubber seal went. You can see the seal that's still on there is in decent shape, the other is torn up and it's not from pressing the center out or I'd have found the pieces.
Test drive proved that was almost all of the vibration. There's still a little something above 75mph and that may be 1 or more of the remaining 3 control arm to knuckle bushings. I will replace them all in the near future. I am really terrible at determining which bushing or ball joint is bad. I knew some bushing on the driver side rear was not right, but I had to get my wife to move the tire while I got under and put my hand on the joints to determine the faulty one.
whtbronco
whtbronco
Winchester, VA
I have found an interesting issue. I can't find OEM replacements for the lower bushing and the upper OEM bushing is $125-150. So I decided to get Moog. However, Moog apparently sells 2 different designs under the same part number. Not the R series vs K series, these are all K80212 upper and K80213 lower. I bought 1 K80212 from Advance Auto Parts and got the design I want that also looks just the Ford design. I went to get another and they only have the other design in stock now. The K80213 from Advance is different and I'm not sure how I could press it in so I took it back. There is only about a 1/16" lip and that requires compressing the grease boots to get to.
I bought another lower from Rock Auto and both upper and lower from Amazon and all 3 seem unusable to me. What I received also does match the item picture from either vendor. I will likely get an OEM upper for the other side despite the 5x cost, but I don't know what to do about the lower. Maybe I'll just keep trying different vendors. I'm not confident in the other brands I have found and I know Moog is not what it used to be, but I think the K series parts are better than ACDelco Gold, Delphi, Dorman, Mevotech which are the other brands I have found.
whtbronco
whtbronco
Winchester, VA
I hope I don't regret this decision, but I ordered some Delphi bushings since they appear to match the original design. We'll see, they should be here Friday.
I need to get this all wrapped up so I can get to the normal annual maintenance, rusted rocker panel on the Expedition and engine seals in my sons Ranger.
whtbronco
whtbronco
Winchester, VA
Well to say I am disappointed in the Delphi lower bushing is an understatement. In fact after reviewing the pics on the RockAuto site I clearly did not get the same item that I wanted, just like the Moog's I ordered. The Delphi bushing I received looks just like the Dorman. In fact the only difference in appearance is the Delphi name and part number printed on it in the same font and color as the Dorman one. I found the Delphi bushing very difficult to install it just did not want to go in straight. I ended up filing it down twice. First the transition from the bevel to the mounting surface was exceptionally poor and basically was a small 90 degree. I tried to install it, but that edge just cut in so it had to go. Then I realized the angle was too steep and kind of curved. Maybe the curve is okay, but it needed to be longer/shallower so another 30 minutes with the file. Now I was finally able to get it started somewhat straight, but while installing I still had to pull it in, then remove the bolt, measure and adjust it with the large socket and mini sledge. I repeated this 4 times before it was seated enough to stay straight.
The upper bushing from Delphi is as pictured, however the bevel is too steep once again and in person I just don't care for the design of the rubber seals so I will return it. I am going to try to find 1 or 2 of what I suspect is the older Moog design. If that fails I will just go ahead and pay the $150+ from the local dealer for an OEM upper.
I don't really want to use the other lower Delphi bushing, but if I do I'll file it down beforehand. I am going to try to find the older design Moog as well, if I can I will replace the Delphi bushing and the passenger side original. I've not found another brand I want to try and I cannot find an NOS OEM lower bushing, so I have to do something.
I used a ball joint press to remove the original bushing, but it wasn't wide enough for the required bits I had on-hand to install. So I just used a grade 3 nut/bolt again. After 2 installs the grade 3 bolt is pretty much trashed, it was just something I had on-hand. I'll replace it with a grade 5 or 8 for the passenger side bushings.
After a couple short trips around town up to 75mph I noticed the coasting vibration is gone. It just doesn't feel right though. There seems to be some vibration from 40-50mph close to wheel speed and it can be felt up to 75mph, though it gets faster and harder to feel. I'll know better after driving it to work the next few days.
I'm wondering if I should go ahead and replace the rear toe adjusters as well. They don't move much and I can't feel or see any play. I couldn't feel any play in the lower driver side bushing either, but it was very easy to move after removing the knuckle indicating it was nearly worn out.
whtbronco
whtbronco
Winchester, VA
Turns out I was unable to acquire any OEM rear upper knuckle ball joint/bushings. Well I found 1 at a dealer in Brooklyn, NY, but I'm not gonna ask my wife to drive 10+ hours to pickup just 1. So I continued to look for some decent ball joints that I could also install, both upper and lower. I have no idea how the newer style Moog ball joints could be installed. It looks like Moog made a tool just for these that they listed for $280 and goes with a ball joint press. However, it would have fit just 1 of the ball joints, it's no longer being made and I could not find any for sale. So the ball joint hunt continued. I went to Advance, Autozone, O'Reilly, Napa and the local Ford dealer with no luck. The local dealer did tell me about the 1 in Brooklyn. In total I have purchased 18 ball joints, only 3 upper units have been what I wanted and what was pictured. I have 1 new Moog upper in hand and another confirmed correct enroute. I am pretty sure I messed up the first 1 I installed and it has a bit of play already. I did not realize it had reached the other side of the knuckle and I kept cranking on the ball joint press, oops.
My wife and I did some troubleshooting to identify the odd feeling and the minor vibration that's left. We found some play in the already replaced upper ball joint and also some play in the forward bushing of the lower left control arm. Neither had much play, but play none the less.
I have given up trying find lower ball joints and the tie rod boots are starting to dry rot. So I ordered OEM replacements from eBay for both lower arms which includes the lower ball joint and 2 new tie rods, $975 ouch. At least these parts should last the remainder of the vehicles useful life. I did not want Mevotech tie rods and I will never use Dorman suspension parts again.
I believe replacing these parts will finally resolve the multiple causes of vibration that I had.
whtbronco
whtbronco
Winchester, VA
I finally had time to replace the driver side rear lower control arm, tie rod and upper ball joint and align it over the last 3 days. The vibration kept getting better with each piece I replaced. The control arm got rid of the 35-55mph vibration. The tie rod eliminated the odd and kind of squirmy feeling, the upper ball joint resolved the vibration from 60-75mph. It feels much better. I never found any play in the tie rod. Even with it removed, but it's not tight anymore, though it's not loose either so I dunno. I confirmed, as suspected, I had messed up the upper ball joint I installed a couple weeks ago. It was very loose and, well no surprise, it was causing vibration.
I had twice rented a ball joint press from Advance Auto Parts, 1 of them was brand new, the other had been abused and I had to file the bolt threads to use it. They worked okay for removal, but I did not have pieces/bits to enable using it for installation. Last weekend Harbor Freight had the Maddox brand ball joint press for $50 and it worked much better. I used only the parts inlcuded with the ball joint press for removal. With a standard length 12point 32mm socket to push and a 1/2" deep receiver cup I was able to use the press to install the ball joint which worked oh so much better than the a 1/2" bolt I used last time. The hardest part this time was simply holding all the bits while I snugged up the press bolt. Just under 2hrs to replace the ball joint, align it and get everything cleaned up and put away. The right tools make all the difference some times.
Hopefully next weekend I can get the passenger side done as well.
whtbronco
whtbronco
Winchester, VA
So after driving it all week the driver side rear suspension parts resolved the consistent vibration. I also noticed that after 20 or so miles on the interstate I get a wheel speed vibration that also seems to have noise with it, I would guess as things get fully heat soaked. Kinda thinking wheel bearing or tire from the sound, but I haven't tried to figure it out yet.
Wednesday I also developed another minor engine speed vibration. There's a good chance it's an accessory so either the power steering pump or A/C compressor.
I reckon someday I'll get everything resolved and it'll stay that way for a while.
whtbronco
whtbronco
Winchester, VA
Not much work going on recently with my vibration hunt, but here's an update. The vibration I thought might be an accessory appears to have been a dirty intake.
Over the last few months I had noticed the idle staying a bit low, like 575-600. Over the last 3 weeks or so I had a couple instances of the idle dropping even lower like 500 and at that rpm it would vibrate. It never did this at 2 stop lights in a row though. I never checked the actual rpm with my scanner just guessing based on the tach, even today when connected my scanner I still forgot, duh. While replacing brake hoses on my sons Ranger today I decided to also clean the intake on my Expedition as it's, I'm ashamed to say, been maybe 2yrs since I have. I had never found a good way to spray the Amsoil Power Foam intake cleaner I use, until today. I pulled the PCV pipe and the truck ran okay, though of course it made it lean. So I grabbed a plastic cap that fit the intake and had a flange to ensure it could not get sucked in. I punched a small hole in it that I could force the spray straw through and this way the intake was sealed up. I was then able to spray the cleaner into the intake until the engine stumbled, shut it off and let it soak, start the engine until it quit smoking and steaming and repeated 3 times. Took it for a short ride after the 3rd round. The idle is now back to about 625 even with the A/C on, it drops down like you'd expect, but jumps right back up as it should, I suppose when the IAC corrects.
I then had the CEL lit up and found 3 PCM codes which is not all that unusual as this stuff causes some yucky stuff to dissolve, mostly the crap the EGR introduces. Two codes for the upstream O2 sensors one was stuck lean, the other was stuck rich, the 3rd code was just running rich. I cleared the codes and ran some errands, about 20 miles and 3 cycles with no returning codes as expected, along with slightly smoother running throughout the RPM and consistent idle.
I never had to clean the intake on a carbureted engine. The fuel kept the entire intake clean. Now days fuel is introduced right at the back of the valve or even direct injection in the combustion chamber so even valves don't get cleaned by fuel.
As noted previously I also have another vibration I have not figured out yet, haven't really tried either. Each time my wife and son ride with me I get a wheel speed vibration, it's my son as it doesn't do this with just my wife. He is 6'3" and 240lbs and typically sits behind me. Seems like the same vibration I have noticed when I am alone and after 25 miles or more sometimes as much as 65 miles of interstate driving. I have been wondering if my struts are wearing and once they get hot if they aren't damping properly. This week when I get home I'll have my wife drive it and I'll follow in another vehicle to see if the tires are bouncing when it happens. The struts are 8yrs old and have 130k miles. The struts seem fine sitting still, and rebound is as expected so I dunno.
whtbronco
whtbronco
Winchester, VA
A few more thoughts.
I don't really have many symptoms of failed or failing struts though. These are Rancho 9000 QuickLift(more like no front lift) 8yrs old and 130K miles. Handling remains fine, there's no significant transfer to the rear during hard acceleration, I still don't slow down for train tracks around here like most people do and it handles them fine with no bottoming and never more than 1 minor bounce on rebound. The known faults are that the adjuster is stuck on setting 9 and it's not as tight as it used to be. I found out the other day the adjuster knobs can be replaced so I will remove once of them and see if I can get freed up.
The other things I suspect the vibration after interstate driving for a while could be are a tire issue that is not noticeable at other times, a wheel bearing or the wheel/tire oscillating a little from toe in to toe out which I believe was the case on the left rear before I replaced the tie rod. I suppose the front suspension could be an issue as well, but I have checked many times lately and I had the guy I use for annual VA state safety inspections check all of the suspension very closely and he found no issues.
whtbronco
whtbronco
Winchester, VA
The suspension or wheel speed vibration I have been chasing recently is not consistent. This morning it was pretty bad for the 35 mile trip to work, and it starts out around 37-38mph. On the way home this evening it was fine until I was just 4-5 miles from home. It changes based on load, such as my son in the back seat. No matter what I pushed, pulled, pried, turned listened to etc I could not find anything loose and out of round. This evening I was gonna mess with the strut adjustment knob and noticed a gap in the rear strut lower bushing and thought that could probably cause this. It's always under serious tension so I wouldn't be able to feel anything by hand, rolling down the road though would be a different story. Whatcha think. This is the right rear, the left rear is the same, the front lower bushings are not visible while mounted.
whtbronco
whtbronco
Winchester, VA
New rear struts are enroute. Rancho has a lifetime warranty against wear out, yet another advantage to Rancho in my book.
From the Rancho web page:
DRiV warrants qualifying Rancho products against defects and wear-out when used on private passenger cars and light trucks under normal operating conditions as described below.
whtbronco
whtbronco
Winchester, VA
So the rear struts have been replaced. That resolved the majority of the remaining wheel speed vibration and I had no change in vibration after driving 20+ miles on the interstate the last few days. That said I was surprised to have noticed a consistent vibration between 50-55 and again 70-75mph. At the 70-75 range the steering wheel even shakes a bit I thought it might be something in the front end even though it was just inspected and the inspector found no issues and he checks my stuff closely by request. I found nothing up front with play or loose this evening either. It does look like I might have a small gap in the front strut lower mounting bushings though similar to the rear, but much less. It's hard to see that though due to the mounting flanges. What can be seen is that bushings are cracking due to dry rot. Maybe it's the front struts causing what's left, if the rear strut mounting bushings were worn out the fronts likely are as well. I also cannot adjust the front struts. I took the knobs off and got those freed up, but inside the strut the adjustment it's rusted solid. Between the dry rot and adjustment maybe Rancho will replace the front struts under warranty as well. You can see a small gap under the bushing in pic IMG_1476, it's nothing like the rear bushings, but it's still there.
The new rear struts have adjustment knob and internal part packed in dielectric grease. I have had Rancho shocks and struts for decades and never heard of doing this, nor have I ever had an issue with Rancho stuff before.
I will add that I will be getting a spring compressor set before trying to replace the front struts. The rear were difficult, but the front are even more difficult and my hands and shoulders are not up to the fight anymore. I used a ratchet strap to hold the rear struts into the mount and used my jack to compress it so I could insert the bolt, can't do that up front.
whtbronco
whtbronco
Winchester, VA
The front struts have been replaced. No need for a spring compressor, just had to disconnect the upper ball joint from the knuckle, remove the tie rod and pop the sway bar loose and the lower control arm could be pushed down enough to get the bottom of the strut in place. I dislike getting the sway bar links on/off so I just removed the sway bar to frame brackets as it's much easier. Then use a floor jack to get the sway bar back up to the frame while you get the brackets mounted again.
The passenger rear toe link was also replaced. The outer tie rod on it is no longer tight, but I still could not feel any play. However, replacing it reduced vibration and resulted in better tracking on the highway.
The remaining vibration is from 65-80mph, haven't been faster this week. The steering wheel is not visibly shaking anymore from 70-80mph like it was previously. This weekend I plan to replace the passenger side rear lower control arm and upper ball joint. Maybe, just maybe I will then be done with vibration for a little while.
whtbronco
whtbronco
Winchester, VA
The passenger rear upper ball joint and lower control arm have been replaced. The upper ball joint moved easily, but I felt no play. The lower ball joint was not easy to move, but it was sticky. It would not move and then kinda stutter as it moved so I suspect the grease had dried up. I only took it for a 3mi test drive, but I think this may the end of the drivetrain vibration. I sure hope so. I'll know better after driving to work this week and then.
I still have to reinstall the front driveshaft. I left it out to ensure the driveshaft and front axle weren't part of the problem.
Here's the parts and tools list in case anyone is interested. Everything was replaced with Motorcraft parts unless otherwise stated. Most everything contributed to minor vibration that added up to major vibration. The front driveshaft u-joint created extreme vibration at times.
IWE's (one failed to hold vacuum) $105
Tires (it was time, so another set of General Grabber HTS60) $950
Front wheel bearing hubs (286k miles just barely starting to develop play) $210
Fuel pump, Bosch $160 (just happened to fail during this lengthy adventure)
Changed rear diff gear oil (was gonna change it in 2-3 months anyway) $30
Rear driveshaft u-joints, slip yoke, straightened and balanced (slip yoke splines excessive play and front u-joint just a tiny bit of play)(Dana SPL non-greaseable u-joints all around) U-joints all 4 $80, slip yoke $125, straighten and balance $300
Front driveshaft u-joints, clean and re-grease slip yoke.(rear u-joint rusted cup keeping driveshaft off center)
Transfer case new bearings and seals (rear bearing for front output shaft ruined by driveshaft u-joint) (USA Standard Gear overhaul kit) Bought 2 kits, 1 salvage yard T-Case and a Motorcraft front output seal. $400
Transfer case shift motor (was causing errors for the 4wd module and other modules on the bus and improperly engaged the clutch coil)
Water pump(weeping a bit and just a little play) $60
Fan clutch(just a bit of play and a little easy to turn) $80
Rear diff torque arm/support bracket (bushing had 3/16" play up, no play down) $205
Found transmission cooler lines rusted while replacing water pump. Cut out the rusted parts and replaced with rubber EVIL ENERGY 5/16" Transmission Hose. Only because I could not find a full set of 5 new lines. $20 (just happened to find during water pump replacement)
Battery failed, Interstate. $125
Harmonic damper. $143
Front main seal. $16
PCV grommet. $10
Rear upper left knuckle ball joint, Moog K80212. $52 (local parts store)
Rear lower left knuckle ball joint, DELPHI TD4312W. $21 (rebranded Dorman garbage)
Rear upper left knuckle ball joint/bushing, Moog K80212. 2 more $64 (I messed up the first 1)
Rear lower left control arm. $306
Rear lower right control arm. $345
Rear toe link. 2 of them $275
Rear struts, Rancho. Warranty replacement, $16 return shipping to RockAuto
Front struts, Rancho. Warranty replacement, $28 return shipping to RockAuto
$3,916 parts total
New tools and supplies purchased during this adventure:
12 point 12mm impact socket for driveshafts, Sunnex. $10
E-Torx impact socket set to replace transfer case front driveshaft protective cover studs, Duratech. $20
Line flaring tool to flare transmission lines, OTC. $40
Deburring tool for transmission lines, General. $10
Transmission line quick disconnect tools (seat the tool and listen for lock release, pull both tool and line out together and the line will unseat), ZKTool. $15
Low profile creeper 'cuz I'm struggling to slide in/out from under the vehicles, ATD. $105
Ratcheting crimp tool for single ear hose clamps for transmissions lines/hoses, iCrimp. $20
Single ear clamps, Oetikar. $25
Transmission fluid for T-Case and transmission lines, Amsoil. $70
Coolant, Prestone. $35
Front main seal installer. 3D printed
Ball joint press, Maddox. $55 (rental units at the local parts stores are just abused)
Foaming intake manifold cleaner, Amsoil. $14
Digital angle meter to set camber properly, Klein. $30
$449 tool total, though I'm sure there's brake fluid and a few other minor costs as well.
Total $4,365
whtbronco
whtbronco
Winchester, VA
Well it turns the passenger side lower control arm and upper ball joint didn't fix anything. I didn't really think they would, but I also didn't think the toe link would and it did. They were as expected nearly worn out though. It seemed to be better Saturday on my short test drive, but the ride to work proved otherwise.
Not sure what to look at now, maybe the tires are out of balance. At 10k miles since the tires were new this seems unlikely, but I reckon it's possible I threw a wheel weight. Well now I typed that I recall that I sure had an issue with wheel weights flying off when the Expy was new. Numerous times it threw weights within 1-2 miles of leaving the dealer. I remember hoping they wouldn't hit another vehicle. An out of round tire seems unlikely since it is so dang smooth now all the way up to 60 or so mph. Just a little vibration beginning at 65mph, gets more pronounced at 70, worst at 75 and subsides a bit by 80. Didn't have a chance to go faster. This is a bit wider range in speed that I am accustomed to with tire balance issues.
kep5niner
Army
MO
Damn that’s a lot of time, money and effort to not have solved the problem. At what point do you just toss the keys to the dealer and say don’t give it back to me until it’s right? Sorry it didn’t work out for you! Yet…
whtbronco
whtbronco
Winchester, VA
Yeah it has been a lot time, money and work. Not to mention recovery. Due to rheumatoid arthritis I can spend a handful of hours working on it and then spend days recovering. Being on-call 24x7 doesn't help either. I put it off, like a fool, until I couldn't stand the vibration anymore. The good news is I have been resolving it a little bit at a time. The driveshafts and the transfer case were the most significant at resolving the various vibrations. The rest kind of nibbled away at it. Admittedly a few parts didn't help much if at all, but they were nearly at the end of their useful life anyway and I generally replace both sides if one has failed.
When does a dealer or a shop get the keys, most likely never, ever gonna happen. I'm stubborn, very stubborn, have nothing else to I can park at work and I can't pay the $170/hr labor rate around here. The other problem is that I am a perfectionist and will try again repeatedly until I get it functionally right. The driveshafts and transfer case would have cost me over $3k alone at a shop. I let only 1 person touch my vehicles, one of my old neighbors for the yearly state safety inspection and that's it. Same for the house and everything in it.
With 293k miles on it, most of the stuff I have done recently I consider maintenance. The ride, handling and fuel economy have all improved as well. The over $4k I've spent in the last 8 months is far less than payments, property tax and insurance on a newer vehicle.
The good news is that almost all of the vibration is resolved and for the most part I enjoy working on it. Up to 60mph it's nice and smooth again and there is no deceleration vibration at all.
Well that was long winded, I guess I often am.
whtbronco
whtbronco
Winchester, VA
Good news, my wife drove the truck quite a bit yesterday and today. She said it's very smooth until 71-73mph and then it starts to vibrate a bit.
Unfortunately I have lost my access to tire equipment. For years I would pay a local shop full price and do my own work when they closed. It was a good deal for both of us. The shop was sold. Now I have to find someone to check/re-balance the wheels/tires or I have even considered buying a bubble balancer. A bubble balancer can produce fine results, but it does take time. I agree a properly maintained and calibrated spin balancer should be better, but that's often not the case.
See I'm stubborn. Even thinking about buying a balancer and an assortment of weights rather than just having it done is stubborn, but I do things my way. It's just who I am.
whtbronco
whtbronco
Winchester, VA
I wanted to visually verify that the wheels weren't bent, the tires appeared perfectly round and the tread ran true as the first step in verifying the tires. My wife asked me not to put the truck on jack stands and run it up to 60mph or more, she gets really nervous as the driver doing this.
I found a shop in town that would allow me to watch them with their spin balancer so I went that route. It did at least allow us to check the balance before before removing the existing weights and all 4 were out of balance. They varied from just 0.25oz to 1.75oz. Afterwards the vibration intensity is reduced by something like 50% and it's not very noticeable until 76-77mph, up from 71mph. None of the wheels appear bent. They would not let me put my hand against the tire unfortunately, but it looked like 3 might be slightly out of round. I couldn't be sure it wasn't possibly just where the dust from the shop floor had been wiped off the tread from handling the tires. The right front tire is clearly a bit out of round.
These tires are worn from 12/32" tread down to 9/32". That's enough wear that replacing 1 tire is not an option with 4wd. I hate to spend another $900-1k on tires again less than a year later. I'll run them for a bit after the rebalancing and make a decision on replacement. I also swapped the right front and rear tires which of course reduced how much the remaining vibration is felt.
Now that the drivetrain issues are resolved, well almost as the tires are not fully resolved yet, it appears the Expedition likes the attention. The A/C compressor has started vibrating lightly when engaged. I had this before and shockingly when I replaced the fuel pump it went away. I'll check the fuel pressure for grins, kind of unlikely it's the cause again. That said the Bosch pump was installed in December. I don't like the way it sounds and the fuel gauge has failed twice. I'm sure it's getting close to time to swap the A/C compressor though. The only part that sucks is getting a someone to evac the system legally.
