My 2001 Lincoln 4x4 Navigator is experiencing PATS problems...I think! My truck starts, idles, runs/drives OK at low speed. Under a load (going uphill or at highway speed) the truck bogs intermittantly like it is starving for gas.
There is no CEL, or codes being thrown to the OBDII port! The THEFT light flashes randomly/constantly at almost 1/sec when the engine is running. Often it will flicker twice, or 3 times fast. The THEFT light is faint, varies in intensity, and can barely be seen in the daylight. The bogging does seem to be tied to the flashing THEFT light somehow, but not perfectly.
First, Before we noticed the THEFT light I replaced the fuel filter (thinking it was clogged,) but it wasn't the problem. Second, thinking this may be the classic electrical corrosion problem, I replaced the GEM and studied the kick-panel/under-dash area for damaged connectors & wires...no luck, no corrosion damage on either side. This isn't a leak problem at the fusebox. Third, I pulled the Instrument Cluster looking for any bad connectors or wires, knowintg the PATS control functions come from there in a Type C Security System like mine. No luck, of course!
Background: I recently did a suspension conversion (to passive springs.) The Suspension Control Module had to be deactivated due to a short in the Compressor Relay. Everything electrical (besides the relay) was left hooked up. I strongly believe this PATS flicker has nothing to do with the suspension conversion: It started after the mechanical work was done, but before the CK SUS light was extingushed by stopping the power to the SCM. After the SCM was turned off, nothing changed. Then I swapped out the GEM for a new one...again, no change.
What do I do next? Where could a short be that could do this? I'm wondering if there are codes somewhere my OBDII scanner can't see...HELP!!!
