OEM Roller follower and Lash adjuster products .. are these REAL?
WrenchinBrit
North Carolina
GlennSullivan
Yorktown NY & Jupiter FL
Hey Guys .. opened up the top end and ready to replace the timing gear .. have got genuine OEM kit and saw this link for the RF and Lash Adjusters ...
Comments seem to state these are OEM .. any thoughts??View attachment 78872
From Ford performance Web Site
  • Fits 4.6L 3V cylinder heads
  • Original production part as used on 2005-2010 Mustang GT
  • Sold in engine sets (24 rocker arms and 24 lash adjusters)
GlennSullivan
They are Genuine Ford. Alot of Ford Performance parts are just ordinary Ford production parts repackaged.
What I can’t tell you is if the 4.6 and 5.4 assemblies are the same, looks like they are but that will need to be confirmed.
JamaicaJoe
Oviedo FL
Curious how difficult it is to change these . Can the cam be left in place?
twodollars
Giving this set a good look. Installing a timing set and high volume pump. Both tensioners had failed seals on them. 106k on truck. Rediculous. Anyhow, the passenger side followers had a noticeable amount of play in them, as compared to driver side. Little wear on cam bearing journals too.
Funny, my 97 dakotas 318 has 230k on it, never gone further in than the spark plugs. Burns a little oil, but runs fine. Overhead cams, meh.
2010ELExpy4x4
California
Did phasers, chains with cast iron early tensioners, followers and pump on a 4.6l.
There are a few tools that make job easier (see you tube videos).parts are same between both except chains and maybe guides 5.4l chains are longer. I think 4.6l has one black link and 5.4l has two or vice versa . Also added Edlebrock high volume water pump for good measure .
twodollars
Yes, just need one of the service tools to compress the valve and then you can wiggle them out. Need to be cognizant of piston location before you try removing. Plenty of vids on you tube a out locating the crank
