Oil Level Gauge on 2019 Expy
Joey Smith
Sunnyvale, CA
Today while driving I noticed my oil level gauge would momentarily dip to low and then return back to the middle.
I have not been driving much during this time and got an oil change around March timeframe and have driven only about 1000 miles since then.
I checked the oil and there is plenty so I am not sure what this means.
Right now the gauge is back to the middle again.
Any thoughts?
Robert McMillan
17plati
US
Any thoughts?
Oil level or oil temperature? Pretty sure if it’s the one on the cluster that’s oil temp
Robert McMillan
17plati
US
I would try catching that on camera and taking it to dealer to fix. Possibly and oil pressure sensor malfunctioning
LokiWolf
Super Moderator
Super Moderator
Richmond VA
The one on the far left of the top set is oil pressure.
If you are having pressure issues, you should definitely get it looked at.
Robert McMillan
17plati
US
If you having pressure issues, you should definitely get it looked at.
Same thing, yeah apparently the Oil pressure sensors behind the alternator have been having issues, especially on f150s. Should definitely get it checked though
Squark
NC
The oil pressure gauge drops to zero when the auto start-stop system shuts the engine off at a stop. It jumps back to normal when the engine restarts. Could that be what you’re seeing?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Nope! Oil pressure gauge does not drop to Zero/Low when Auto Start/Stop turns the motor off. That would cause unnecessary panic. People would think something is broke. It holds at what ever position it was when it shut the motor off.
If you were looking at the actual pressure on something like FORSCAN or VCM(HPTuners), yes you would see the pressure drop, but the factory digital gauge does not move.
aggiegrad05
North Texas
Yes, this is a much better (and more complete) way to say what I did. If you’re in a vehicle with analog gauges (like an XL F150) it will drop on ASS, but the digi gauge doesn’t.
