Oil pump and rod bearings.
rescuer3
NC
Okay, engine lost oil pressure and started knocking a little. Pulled the oil pan to find some metal in it. Pulled rod caps, number 1 has spun, 3,6&7 have some play. No scoring or damage to the crank. It is a 2003 5.4 with 170,000 miles. My question is should I change the oil pump when I replace the rod bearings or did the spun bearing cause my drop in oil pressure? Any advice is appreciated.
JUST4FUN
Admin
Moderator Administrator
Il
If your in replacing the bearings (all ) including the mains replace the pump
rescuer3
rescuer3
NC
Not replacing mains, engine is still in the truck.
JUST4FUN
Admin
Il
I don't know, if it ran with out oil pressure. id think do the whole thing. if the rod bearings are bad . just replace # 1 and try it. see if it knocks
rescuer3
rescuer3
NC
Thanks for the advice, this is a low priority project right now but I will update when the rod bearings and oil pump are done.
