JimmyM
My right high beam is out. It won't light at all. High beams or flash to pass.
I checked all the fuses (7,8, & 23 inside). The left side high beam works fine.
I have Anzo housings, but replaced the left side with the old housing to test. Still no luck.
I've swapped bulbs and get no light either.
When I check the voltage at the wires with no bulb in, I see 12V with the high beams on. When I put a bulb in and then check the voltage again. I only get a few hundred millivolts.
It seems as though there's a high resistance in the right side high beam circuit.
Thoughts?
Is there a high beam relay somewhere? I couldn't find one in the interior or under hood fuse blocks.
Thoughts?
