Ops!
toms89
technical advisor
MD
I know what my expy runs in the 1/4 mile and 0-60 so today I decided to see what her top speed is. On a deserted stretch of hwy running through Baltimore I opened her up. Hit about 157 mph (gps) before I decided to let out.
Think I may have hurt her though as now there is a loud knocking noise coming from the bottom end of the motor...
stamp11127
Temple, Georgia
As long as nothing parted company, it is repairable as you know.
The real question is ----- Was it still pulling and what was it turning at that speed????
toms89
toms89
technical advisor
MD
Damn! Now I feel guilty for posting this thread :p
I tried to keep the story within the realm of possibility.:evil27: But as curious as I may be I have no plans to test the top end.. There is also no such thing as a deserted road in baltimore. Always traffic.. :(
Whack
St Louis
You got me... now to relatiate with math!
Assuming 1st gen Expy with:
Unlimed power
5500rpm RL,
Stock 4r100 ratios,
3.73 rearend,
265/70r17 tires
5500 rpm / .71 4th gear / 3.73 final drive = rpm at tire = 2076.80rpm
265-70r17s -> 99.293in circ = 8.274 ft *2076.80rpm = 9044.76 fpm = 3.254 mpm =
195.267 mph (205.98 with 3.55 rearend)
toms89
toms89
technical advisor
MD
Unlimed power
5500rpm RL,
Stock 4r100 ratios,
3.73 rearend,
265/70r17 tires
Since I do not have unlimited hp....
I have 3.55's but my rev limiter is set at 6,000 rpm. Shift point is 5,600. I really do not think it would have any trouble winding out 3rd gear or 1 to 1 ratio which would be 145ish I believe. Overdrive is obviously going to be aerodynamically limited vs the powerband.
Stock lightnings top speed is around 147mph. But I am making significantly more power than a stock lightning. Weight is really not a factor for top speed by aerodynamics certainly is!! My guess is it would be a little better than a stock lightning due to the increase in hp but then it is far less aerodynamic due to the 4x4 stance so who knows? It also has additional parasitic drag due to the 4wd components spinning..
Motor Trend: Ford SVT F-150 Lightning Earns the Title 'World's Fastest Production Pickup'
superexpy
Covington wa
I had mine at 140 when I let off. I know this because my buddys m3 was trying to keep up....
mc0311grunt
victorville
I actually got mine up to 113 (no speed limiter) today. That was off road. Granted it was a dry lake bed (el mirage dry lake bed). It was actually smooth. The car we were testing hit 149.593mph according to the radar.
tallsville
LA
on aerodynamics for a 2nd gen frontal area of 60sq ft. it would take 1500 hp to hit 200mph. if i can find the calculator i used i will post it.
Whack
St Louis
I did say unlimited power...
I don't even want to think of the cost in a 1500hp+ Modular V8 build...
toms89
toms89
technical advisor
MD
Fastest I have been is 129mph but that was in my mustang in just 1320 ft. The expy can only hit 107.44mph in the same distance. I do hope to improve upon that in the future but it will have to wait. More $$ and time needed.. :(
Have all kinds of ideas but short on funds....
