passanger door from inside not opening
mrazndead
asdf
so my passenger door won't open from the inside. i made sure the child lock on the door hinge is set to unlock. the door opens from the outside just fine. but from the inside it doesn't open. any help?
JUST4FUN
Admin
Moderator Administrator
Il
easy fix, take the plate off the child lock switch. spray WD40 in to the hole and work the switch up and down . Put the plate back on and the switch in unlock it should be fine
JUST4FUN
Admin
Il
Take the plate off and put it in the unlock , see if that works with out the plate
M
mrazndead
asdf
wow it worked!
I took off plate. sprayed a bunch of wd40 in the hole. and switched it up and down. and the handle works from the inside.
shadow460
Oklahoma City
I'm gonna have to try WD-40 myself. My left rear door won't open from the inside. That makes me feel like I'm driving a police car or something.
