Passenger side mirror freaking out
ETC13
TN
Interestingly enough, I had this done and though it was fixed... What it actually does is stop the mirrors from hunting but it doesn't actually solve the problem. Most people won't notice it because they don't have 2 different mirror settings that are very far apart from one another (or it's just an additional issue that's unique to my vehical, or possibly temperature related).
If you want to see what I'm talking about, take your passenger mirror and move it down and right from your current setting in bank one ( a decent amount). Wait about 10 seconds. Press bank 1 to return the mirror to where the memory position is. Press bank 1 again and see if your mirror moves again... Then press bank 1 again and see if your mirror moves again... For me, sometimes I have to press bank 1 up to four times to get the mirror back to the actual bank 1 position.
While I thought it was fixed, it really isn't a 100% fix, the update just keeps the mirrors from freaking out. It doesn't make them find their correct positions with one press. At least it didn't for me.
Mine just got the update and does not do this. At first the passenger mirror would not move to proper bank one or bank two memory positions. Just had to move it to the position for bank one and re-save the setting and then do the same for bank 2. Switching between the two or even moving the mirror and then hitting the bank places both mirrors properly to their preset position on both banks.
Sent from my moto g(7) using Tapatalk
ETC13
TN
Basically I think it is best to just go back and set up everything from scratch after the update is done. Mine also lost the auto fold setting and needed to be enabled again via the dash settings, however did not lose the auto window up.
So a re-save of all your settings sound in order after this update.
star-art
Pacific Northwest
As far as I know, yes.
Here's a quick question related to the mirrors. For those who have power-fold mirrors, will they fold using the switch when the ignition is OFF? I don't drive our '18 very often, but I seem to recall not being able to get the mirrors to fold/unfold with the switch unless I turned the ignition on. I found this to be very annoying as I expected them to work at any time.
Thanks! :)
ETC13
TN
Thanks! :)
I don't believe they do unless at least hitting the on button. To me this would be like expecting the windows to roll down without hitting the button. The module would need constant power for this to be the case.
star-art
Pacific Northwest
For decades electric mirrors were powered so they worked with the ignition on or off. I always expected something like the fold control to operate the same way. The module that controls the mirrors (the Driver Door Module) does indeed have constant power. As I recall in some other Ford models (like the 3rd Gen Expy -- again IIRC) you can fold them with the ignition off. Obviously, you aren't going to do that unless you're sitting in the vehicle. I know I needed to do it on a couple of occasions (like when parked in a tight spot, waiting in the vehicle and someone was trying to get into the next vehicle and I wanted to protect the mirrors) and I had to turn on the ignition before they would work. At any rate, thanks for confirming this. :)
Dale204
Manitoba, Canada
I have a 2018 Platinum Max and have experienced this issue as well. (Correction) If I switch from one seat preset to another with the engine off, the mirror will continue clicking. If I start the engine and then change the preset... I've never experienced the clicking. I was able to replicate this scenario consistently.
CJJB
Missouri
I've had our 2018 at the dealership several times and I always get the "unable to duplicate issue" statement. I even mentioned I'd read it was a software issue but so far it's not been fixed. It's such a random occurrence it'd be nearly impossible to duplicate while at the dealership. Ours started at around 7000 miles and it's got a little over 20,000 on it now. It'll probably wait until right after warranty to finally quit completely.
aggiegrad05
North Texas
That seems strange to me that they want to be able to duplicate the issue to reflash the software. I (and I suspect most others that have had the issue fixed) just told the dealer it was doing it, gave them the TSB number, and had it fixed.
Good luck
Squark
NC
If you can take a video of it happening they might be more willing to help. Also give them the TSB number if you haven’t already.
DenSanAZ
Arizona
I had this same issue with my '16 Explorer. When the mirrors were retracted and, when using remote start, the mirror would start clacking away inside the casing, it was constantly trying to adjust outwards then *clack* back in 1-2 second cycles, and continue doing this for about 30-45 seconds before stopping (timing out, perhaps?). It mostly happened when it was warmer outside (Phoenix, so from Apr to Nov!). I brought it up with the dealer during a service call and got the "unable to duplicate" response. Brought it up again at it's next service and was told they "replaced both mirrors" (which I really don't think they did). I had the car for 3 years (traded it for the '18 Expy) and it was still doing it the whole time - completely at random but only when using remote start. On my '18 Expy, there have been a few times the mirrors won't extend right after being retracted and I've not even had it a few months. Mirror gremlins in Ford mirror motors, perhaps.
Gumby
Beaumont, Alberta
Good luck
This is literally what I did. I could replicate it, but of course the dealer couldn't....So when I was in last, I said here is the SSM, I would like it updated.
Atticus Mabrry
Greenville, SC
Mine was fixed...but they charged me to do it...which is absolute BS since it was a Ford software issue in the first place. At least it no longer does it.
Jamaican Cruiser
Vienna, VA
I started having the mirror issue yesterday :(. Called a dealer close to me and he said to take it in as there is an open TSB on the issue.
I was already taking it in for the Pana Roof
Ford TSB SSM47713
Date: 12/17/2018
Title: 2018-2019 Expedition/Navigator - Exterior Mirror Glass Intermittent Clicking Or Ratcheting - Built On Or Before 5-Dec-2018
Models:
  • 2018-2019 Expedition Limited
  • 2018-2019 Expedition MAX Limited
  • 2018-2019 Expedition MAX Platinum
  • 2018-2019 Expedition MAX SSV
  • 2018-2019 Expedition MAX XL
  • 2018-2019 Expedition MAX XLT
  • 2018-2019 Expedition Platinum
  • 2018-2019 Expedition SSV
  • 2018-2019 Expedition XL
  • 2018-2019 Expedition XLT
TimberExpy
Florida
Well I hate to resurrect an 3+ year old post, but our '22 Timberline has started to do this with the passenger side mirror. Very intermittent.
When we pull our Expy into the garage at night, we need to fold the mirrors in as we pull in; otherwise the vehicle would not fit through the garage door. So the mirrors don't fold into their position when the truck is locked, b/c they are already in that position. In the morning when the truck is unlocked, the mirrors understandably stay in the folded position b/c the computer knows that they were 'manually' put there. But about a minute after starting the engine, the clicking/ratcheting noise happens on the passenger mirror - without any driver input (we don't hit the button to unfold them or anything). The clicking lasts for a while, and then eventually stops.
Once we pull the truck out of the garage and hit the button to unfold the mirrors, the mirrors unfold and otherwise operate as intended.
So I guess the "Built On Or Before 5-Dec-2018" TSB doesn't apply anymore... there are newer vehicles that have this issue.
