Hello Everyone,
Last night my passenger window fell down as I was putting it down, It tilted forward and then fell into the door. I have removed the door panel and made sure everything was intact. I have found the the linkage between the inside handle was stuck in one of the clips that hold the window and now the door will not open from the inside. I can put the window back in the track, I was wondering if the clips that hold the window on the track are suppose to be bent or not, the one that caught the linkage is a little bent from the other one. Also does anyone have a picture of the inside of the door panel that shows the linkage and what it is suppose to look like.
Any other advice would be great also.
Thank you,
Calvin
Thank you,
Calvin
