Transporter
Please read the whole post then make your suggestions.
Front Passenger Window will go down but not up.
I have a new known good drivers side window control because the driver's window would not go down and it was the module so I replaced it and I used the old one that worked the passenger window before to prove the new driver's module is still good as this new problem started months after replacing the driver's module. I moved the passenger switch to the rear window and the switch operates the window properly up and down. So both Driver's switch and passenger switches are known good.
So the motor should be good since it will go down, both switches are proved good, what else can it be?
