pcm replaced now hydrolocked
fattywaters
Louisville
I had a local shop replace my pcm and now my engine is hydrolocked. It had fuel in all cylinders, making me think that it was a problem with the new pcm, but I'm not sure if there is a function in ford IDS that can command the injectors on and make it do this as well... any help would be greatly appreciated. I want my expy running again, I just need to know who to have pay for my replacement engine I'm going to need now...
stamp11127
Temple, Georgia
Pull the plugs, rotate the engine slowly to pump the gas out and scope the cylinders for damage. Then make a decision on what to do.
stamp11127
Temple, Georgia
Did they just replace the pcm? From what I remember, the pcm is tied into the PATS. Unless the system has been reprogrammed with the correct key you'll have a no start condition (no spark). Check how fast the theft light is blinking and if you want check for spark.
F
fattywaters
Louisville
the new keys have been programmed, the engine injectors got stuck in the on position either by the pcm or with fords IDS software, I just dont know which one it was that got them to stick on long enough to hydrolock my motor. and the pats function will disable the fuel pump and injectors on this model, everything else will work
stamp11127
Temple, Georgia
Look at it logically, it takes three things for an engine to run:
fuel/air (check fuel pressure & listen to the injectors with a scope)
compression (do a compression check on a few cylinders)
spark (pull a plug or use an inductive timing light on a wire to check)
One of them is missing or out of time
Another way to check for lack of fuel is starter fluid. If you go that route use it sparingly. Can have a major bang if you use to much and it backfires.
What are the chances all 8 cylinders have 0 psi on your engine?
What happened to require the pcm to be changed?
JUST4FUN
Admin
Moderator Administrator
Il
Remember if your trying to crank the enging with a weak battery things won't work right
F
fattywaters
Louisville
after changing out the spark plugs again and reluctantly letting it air out for a few hours and recharging both batteries... she fired up with a lot of smoke from the exhaust because of the fuel dumped into the exhaust system... now to get it running right and hope the rest of the fuel evaporates out of the exhaust without catching it on fire... lol and yes I am just letting it run for a couple of seconds and then letting it cool down and trying to evaporate it that way.
and I am running 2 batteries for the simple fact of more is better...lol
Crash!
Tulsa
Don't forget to change the oil. It is possible the oil is contaminated with fuel. Keep us posted! If you were just starting it up, you should have no damage. If you were under load, you could have run into real problems.
Let us know if you have anymore issues. This has happened to my car, while my girlfriend was driving, and she hit a flooded area on the road. It immediately locked, but did not cause any damage. I did the same thing you did, and it took care of the problem.
stamp11127
Temple, Georgia
Did it smoke like a mosquito fogger or just the normal morning startup? Coolant level staying the same?
F
fattywaters
Louisville
Coolant the same, just fuel in exhaust system and in oil as well, drained about 8 quarts of oil/fuel out of oil pan
stamp11127
Temple, Georgia
Listen to the injectors with a scope. You'll hear the bad ones. If you have a fuel pressure gauge the pressure will drop to 0 rather quickly when you turn off the engine.
F
fattywaters
Louisville
just test drove it around the block a couple of times, all seems to be ok for this time. no more fuel in oil and coolant level stayed the same, a little more smoke than usual at startup now but that is almost to be expected with the fuel in the cats... but much better that the fog machine it was before I changed the oil
