Phone keeps disconnecting!
iamhollyb
Dallas, TX
My phone worked great with my 2014 King Ranch edition until this morning. Took a call from my husband on the way to my daughter's school, she hopped out with her iPod touch and disconnected it from my truck (Bluetooth) and the very next call I took wouldn't work with my Sync. I have an iPhone 6 and have never had this problem before.
I have turned the truck off and on, deleted the device a few times, turned Bluetooth off and on, done some kind of reboot, and it will connect for a second then I get "Bluetooth disconnected" and "no paired phone found" before it disconnects again.
Help?!
I
iamhollyb
Dallas, TX
Also, I can still play podcasts from my phone through the stereo, which seems weird to me. Just no phone service.
FordIVTteam
Dearborn, MI
Temple, Georgia
I'm impressed with the blue oval team. This is the first time they have responded with a real "how to" instead of take it to your local dealer.
5 "Ata boys" for them!
FisherPete
Portland, Oregon
After several years of flawless blue tooth connection, my Droid Maxx has been having trouble over the last couple weeks. It only pairs about 1/2 the time. It's great to have some tips to see if I can improve it. Typically I don't notice that I'm not paired until the phone rings and isn't coming through the SYNC. I'm going to try a clean pairing and if that doesn't help I'll try the Master Reset. Frustrating that it's intermittent, but whaddya do?
I
iamhollyb
Dallas, TX
Well shoot. I turned everything off (phone, car) and let it sit for a bit then turned it all back on. Turned Bluetooth off and back on. Tried to delete my phone from my Sync, and it just won't go away. Performed a Master Reset and my phone still shows up.
I deleted Sync from my phone and then re-connected it. And it worked for a few seconds. Then it disconnects again on the Expy side and says no paired phones found. Ugh.
dlcorbett
Air Force
tx
I had the same problem with my truck. I didnt know what to do as i turned off my phone and all but nothin worked. What i did was disconnect all bt devices. I then cleaned my cache to my phone and did a hard reset on it, do not just turn the phone on and off as the hard reset updates your phone, not the powering off of the phone. My phone was a bit older so it needed to be done anyway but a hard reset needs to be done on all phones atleast once per wk. After that i connected again and since have not had a repeat problem.
I
iamhollyb
Dallas, TX
I can't get my truck to delete my phone. I got it to delete my daughter's iPod. But my phone continues to show up. And by hard reset on the phone, do you mean the power and front button at the same time until it restarts?
k9education
It never hurts to do a hard reset and sometimes it's necessary, but if you have to do it that often there's another issue with the phone. I do a hard reset on my iPhone 5S once every 1-2 months and have no issues with it in the interim.
Anyway, +1 on the hard reset for this particular issue. Remove the device, shut the vehicle off, hard reset the phone, and try to re-add it.
Temple, Georgia
I'm curious why this is happening to you so I've been "cruisin the net". I don't have an iphone so I can't determine if options I've read about are still valid with the latest and greatest.
One thread I came across state to make sure "always connect" is checked in the bluetooth settings on the device being paired.
Another states to disconnect the vehicle battery for 5 mins to cause a hardware reset on the vehicle then go back through the pairing process. Other modules in the vehicle may lose memory settings, seats - radio etc.
Check for updare:
https://owner.ford.com/tools/account/how-tos/keep-your-sync-up-to-date.html
dlcorbett
Air Force
tx
Make sure youre deleting your phone on both phone and media settings, i forgot to mention that sooner. It wont do you any good if you do these steps only for media and not for he phone. You will do this in media>user device>bts>devices screen as well as the phone>devices screen.The screens look similar but theres a separate connection screen for phone and media. I discovered this when messing with my phone. Also, if your phone is set as a favorite, youll have to take it off favorite first then delete, and youll have to make sure its not on favorties for both phone and media settings. You may not have to do a hard reset often since you have a iphone 6 but if you had the phone for awhile and havent been prompted to do one in about a mnths time i would def recommend it. Unfortunately i do not have an iphone so i dont know the hard reset process on it but googling Or youtube it will help. Dont give up on it either, it will work again, its just a bit more intricate then you would think it is. My 15 mazda 6 used to give me problems with bt and the fords is worlds more advance and these trucks have older systems as well.
FordIVTteam
Dearborn, MI
Hey iamhollyb,
Have you tried performing a master reset? The instructions can be found in the link above Rebecca provided.
Whitney
I
iamhollyb
Dallas, TX
I did do a master reset a couple of times and nothing...then on Saturday I got a call and lo and behold, it routed through the truck! I hadn't done anything except for give up on Friday. It's been working fine since. So annoying that it wouldn't work, but I'm glad it's working now!
Temple, Georgia
There is another possibility we didn't address:
wait for it........
the ol' seat - steering wheel interface.......
Sorry but couldn't resist - it was a long day in the "land of the __________"
I
iamhollyb
Dallas, TX
Lol! Yah, that wasn't the problem. I'm completely baffled as to why it wigged out. I tried to delete it from the phone as well as media lists, deleted Sync from my phone, did master resets (where it didn't delete anything), turned my phone off and on... Just weird.
rwmorrisonjr
Memphis, TN
I've found that my iPhone 6 Plus doesn't play nicely with my 2012's Sync system. It won't always automatically connect, even if the phone if sitting in the car. Most times I need to manually force a connection. It's annoying, but I've gotten used to it. I almost wish I didn't have the sync system since my Alpine head unit has better Bluetooth, but I like using the integrated microphone so I don't have the Alpine one hanging off the headliner. Other than that, Sync is useless to me.
Sorry I don't have a better contribution or solution to your BT issue.
FisherPete
Portland, Oregon
I posted above, but for those who missed it, I have the same symptoms with my Android Droid Maxx. I don't think it's a phone type issue, but it could be that software updates on the phone have progressed beyond Sync technology. Even after paying for a SYNC update, I still have the problem. Really irritating that software updates are a FORD profit center. I like the Google model a lot better.
rwmorrisonjr
Memphis, TN
How did you pay for a Sync update for your 2012? I haven't seen where Ford updated the Sync system for our trucks.
FordIVTteam
Dearborn, MI
Hey everyone!
Sit tight and keep periodically checking your Owner.Ford.com accounts for a new SYNC update. I don't have an ETA, but my sources tell me soon. :)
Rebecca
