Poll about 5.4l V8 and mileage
5.4l V8 and mileage
  • You are under 100k and have had major issues.
    Votes: 44 8.3%
  • You are over 100k and have had no major issues.
    Votes: 223 42.0%
  • You are over 150k miles.
    Votes: 164 30.9%
  • You are over 200k miles.
    Votes: 88 16.6%
  • You are over 300k miles.
    Votes: 12 2.3%
  • Total voters
    531
cbiii
Independence, Mo
1999 EB. 190k cluster**************** of issues (several posts about it) as well as no AC, heat barely works, wheel studs snapped while driving, passenger door doesnt want to unlock from the key, passenger rear window doesnt want to roll up.
portponies
Port Washington
'97 EB 5.4 4x4
234K miles
Engine and trans have not been opened up - yet.
Tires, brakes, and muffler all have been replaced at least 3 times.
Tie rods and ball joints once.
No major problems to speak of.
Still tow car on open trailer with ease.
jacks3am
michigan
97 EB 5.4
have had a new window regulator, 2 new rims since 2 were cracked, 4 new tires, all new shocks, it needs rear springs, new tierods, new torsion bars that are of a different stiffness, matching rims, probably new seat covers or just new seats and some major de rusting/frame painting!
arthurjarrels
california
188,000 1999 xlt all stock so far. had a helicoil on cylinder 2 at 150,000. heater tube leak a couple weeks ago, which was a job. but nothing else to major.
fixitmyself
Chicago
2003 eb 5.4
2003 EB 5.4, 147,000 miles. no major problems other than Power Steering Pump replaced, fuse block replaced (due to burned out fuel relay inside block that cannot be replaced individually), driver seat motors froze, Radio/ Nav system replaced due to blank screen, one reverse sensor replaced ($125 each), all 8 spark plugs and coils replaced (one coil went bad- just changed them all) now have a leak in the right rear differential axle shaft seal (still trying to figure out if I can do it myself or have to go to dealer and pay big$$$). I strongly believe this car will run past 200K miles. I'll probably keep it til it dies.
PaulMedik
