poor lighting
acrbill
Chicago
The headlights on my 98 are very poor.
Without the fog lights on, they are near worthless if your driving over 30MPH.
Is there an aftermarket headlight assembly that has a clear/ non fluted lens?
The few I have seen use a projector. In my past experiances, they throw out less light.
Does anyone have installed pics of aftermarket headlights?
thanks
flakito1000
Virginia Beach, VA
I would suggest to inspect the wiring of the headlights. Usually inside the engine compartment the wiring may get corroded specially if the insulation is punctured or not protected properly.
If everything looks good replace the lighting relay (I think is inside the engine compartment inside a little black box) or it could be your alternator, it may not be producing enough juice.
Check battery voltage as well, battery may be too old to handle the brightness of your lights.
JUST4FUN
Admin
Moderator Administrator
Il
Is this an aiming problem
JUST4FUN
Admin
Il
:D
