Power Locks
ExpoBOI
IDAHO
Anyone know if there is anything you can do about sticky locks they always lock fine but sometimes when you go to unlock you have to push it a hundred times or push really hard. Its frustrating.
sniper141
Beaver Falls, NY
You are more than likely having actuator problems and will have to replace it. I have the same problem with my 2000 xlt in the front left!
E
ExpoBOI
IDAHO
But the problem happens with both doors, however, when I use the key chain clicker it unlocks them and locks them just fine.
ELVATO
Orlando, FL
So you're thinking it could be the switch itself? Does it do it with both the driver and passenger lock switch?
E
ExpoBOI
IDAHO
Yes on both doors. But only from time to time and if it doesnt work and I hold down the unlock button then it works or if I excessively push the button several times
