gulfman
Does anyone know the procedure for programing a new backup aid module. I understand it requires driving the vehicle at a certain speed and stopping and doing some other weird stuff.
Bob
Bob
Thanks Bedrck46. The information was very helpfulThe following was copied from the Ford workshop manual
Park Aid Calibration and Self-Test Diagnostics — Navigator, Early Build Expedition
Connect the diagnostic tool.
Place the vehicle in PARK.
Select the appropriate vehicle and engine.
Enter the active command mode for the parking aid module.
RUN the radar sensor calibration active command.
Exit the active command mode.
RUN the park aid on-demand self-test.
RETRIEVE and CLEAR any DTCs. REFER to DTC Index.
If any DTCs remain, Go To Pinpoint Test B .
if you do your own work you may find the following very helpful;
Ford workshop manual on DVD. Can be obtained from seller "morpheousking" on e-bay. Cost about $10.00 Much better than Clymer, Haynes or Chilton and also includes wiring diagrams
Don't waste your money on a Clymer, Haynes or Chilton Manual.
It is well worth the $10.00 just make sure you get the DVD for your year as the seller has different DVD's for different years
No I am not. I have found these manuals to be very helpful not only for myself but also in trying to help others I have also had the other manuals and when comparing what you get on the DVD's there is no comparison to the information that is available on the DVD's. IMHO they are worth much more that what he charges for them.
Does anyone have a site for a DVD service manual for a 2003 Expedition?
Bob
