wiring harness for amp detailed
ok heres the amp harness explained the best i can.
i went back and opened up the harness to try and show whats going on
this is where it splits from the main harness
here ive cut it open so you can see all the wires are split up in to groups
heres the break down of wire colors
these are the wires from the larger plug in the amp they supply power for the amp and go out to the speakers
1. blue is the amp trigger aka remote wire aka amp turn on
2. black with green stripe is ground for amp
3. green with violet stripe is +12 volts
4. black with violet stripe is right rear -
5. orange with red stripe is right rear +
6. dark green with orange stripe is right front -
7. white with green stripe is right front +
8. tan with yellow stripe is left rear -
9. gray with light blue stripe left rear +
10. light blue with white stripe is left front -
11. orange with green stripe is left front +
once you cut it open there will be another harness with in this is what comes from the radio
in this smaller harness here is the break down of wires in it
1. light blue is right rear -
2. purple with white stripe is right rear +
3. brown is right front -
4. white with dark red stripe is right front +
5. yellow is left rear -
6. light blue with black stripe is left rear +
7. white with orange stipe is left front -
8. green is left front +
well there it is to the best of my color blindness lol. if you guys see a wire that is not quite the color i said it is let me know and ill fix it like i said im not good with colors thats why i didnt do the colors the first time but there it is. and if you guys have any other questions let me know ill be happy to try and answer them.
