08navigator
Hello everyone! I'm new to the forum and hoping to learn from you folks about our newly bought 2008 navigator. She has 124k miles and besides a few issues appears to be a great vehicle.
I'll break down the possible a/c leak
I test drove the car on a 94 degree super humid day. The AC was set at 60 and was blowing slightly cold but definitely not working correctly. I figured a 10 year old vehicle, it probably need evacuated and recharged.
After buying it it no longer was cold at all and just blows hot air. I noticed right by my rear passenger tire it appeared I had green coolant leaking out. I ran the heat and truck after cleaning up the small leak and no coolant ever reappeared.
After contemplating this I came to the conclusion that it was probably my refrigerant leaking out with some pag oil/green dye. This would make sense since it's no longer blowing cold. So the good news is that it seems my compressor works but I do have a leak.
Is there a condensate drain right at the rear passenger wheel? If it's leaking out of there it would be my rear evaporator leaking correct? If not, it's probably the rear ac line somewhere.
Any input is much appreciated!
Sent from my Pixel XL using Tapatalk
