08navigator
Tapatalk is doing something odd with this thread. I didn't see this post earlier and now it has separated some of your replies into a separate thread with the same title. Weird. Anyway, thanks for the info! The location of the original hole was about the worst possible spot. It could not be bent out and you could not in anyway get a compression fitting in that tight spot. I bought some kwool(fire blanket insulation) to cover everything else in the area before attempting brazing but it just wouldn't take. I cut the line in Easy to get compression fittings on places so hopefully this works out.I don't see where its so close to a bend that you couldn't put a compression fitting in there. You would have to work the line out away from frame some and in worse case cut it to make area more accessible and add new line to meet at places where it is accessible.
I see you are going the replacement approach. You don't have to do the whole thing or any more than what you need to to put the connections in good to get to areas.
A cheap old brass compression fitting will work but the better ones are "better".
It is the high side liquid line so NO sealers or rubber and clamps will work.
I have tried it all.
JB weld only slightly slows it, rubber with pressure usually still leaks too much. You are talking about 225-300 PSI .
You CAN use rubber if you get AC pressure line which is also barrier hose but without barbed ends to clamp it too with high quality refrigeration clamps....the line will blow off even if you double or triple clamp it.
With rubber you could cut off at convenient to get to place and get a compression fitting that you could screw another adapter and then a barbed male end into that so you would have a barbed end connected to your existing line but that makes more connections than just putting in some aluminum tubing in two places like you are doing.
PAG 46 is correct as mentioned and I can't swear if one with a rear ac only holds 3-3.5 oz but I would add 1-1.5 oz. Do you have injector or are you going to use a pressurized store bought can or try to get it into the line as you do the work?
Pump it down for at least 30-45 mins when done. Should have gauge set hooked to both low and high sides and both gauge valve open to pump down both sides.
You can then close valves and tun off pump and see it it holds vacuum bur I get too impatient for that.
You will see a leak when you charge it.
I like to charge the first can in as a liquid upside down even if I have to go in low side like normal, just with compressor off. A big system pumped down like that should take a can with no help from compressor to suck it in.
Then wait a 5-6 mins while you are looking for obvious leaks at the splices before starting second can upright gas and starting engine and turning on compressor to charge up rest of way.
I would expect 3-4 cans but I don't remember what year were are taking about.
If I can't fix the AC we will probably be dumping this thing. I have three young kids and the Midwest sucks ass in the summer with humidity. I may block off the rear if it comes to that and see how that works out. It's just not worth spending a bunch fixing something like this on an older suv(2008 navigator 136k miles).
I'm buying a vacuum pump and ac manifold off Amazon. I plan to pull a vacuum for half an hour, close the high and low sides and see if it holds. If it holds I'll pull vacuum again for another hour I think to make sure all of the water is out of there and then charge it. So I should add a bit of pag oil to the hose with some dye, clip the center hose onto the manifold and charge the first can upside down with the AC compressor off? I know the vacuum will pull the 134 in but will it get the whole can in there with it off? Also, dont I want the compressor on to pressurize that high pressure line to check for leaks?
Sent from my Pixel XL using Tapatalk
