Rear ABS Sensor
warddaman
Trenton, OH
My ABS light came on and Advanced Auto informed me that the code was for the rear ABS sensor. Has anyone ever replaced this? It looks fairly straight forward. Any pointers or instructions?
DF5.4
Hilton, NY
If it's anything like the one on my 99 F-150 its 1 plug and 1 bolt on top of the differential. I think it took longer to get the tools out and clean up than it did to actually change it.
Thermo
technical advisor
ward, a little hint, drop the spare tire out of the way first. This will give you some room to move around. From there, like was mentioned. Find the top of the differential, you will see the wiring coming down from the body, undo the plug, remove the bolt, lift straight up. Install is the reverse.
walnuts4x4
Watertown, NY
yeah I think mine died again... my ABS light came back on every now and again... and my front wheel bearings were replaced so hoping its just the sensor...
W
warddaman
Trenton, OH
So I removed the bolt and tried to pry the sensor off and ended braking the sensor. The cap around the magnet is stuck/rusted to the diffrential. Does anyone know what the cost will be to fix that?
W
warddaman
Trenton, OH
Alright I found a guy who is coming out to my house tonight to remove the diffrential plate and knock out the ABS piece. Labor is going to cost $50 -$100. Do you think thats a good price?
