I need a bigger jack, just have a small one here. If you thinking about it, I would def buy a new set of trailing arms with hardware, makes life easier. The bolts on the arm in the axle were frozen fast to the rubber. After you get the rear out, Id put the tires back on so you can move it around a lot easier. Learned that the hard way, ouch. Also double check hardware, to see if you need to enlarge the mounting holes on body and new rear. Putting the body high in the air is up to you, I just put mine high enough so the tires were off the ground. Good time to check rear sway bar endlinks too, I replaced both mine. Oh yeah, have a good impact gun, I used my dewalt cordless, but also had to use my breaker bar too. Front left lower trailing arm bolt may need to be cut in two since it hits the gas tank and you can't get it out. What made things nice for me, is that we have 3 cars, so I could take my time and in case I ran into something I didn't need to rush. If you are thinking about this, make a parts list and get all your parts ahead of time, makes life easier. Time wise, you should be able to swap out in a weekend. Hope this helps.
