Rear hatch dirt and spray build up
NvrStk
MN
Anyone else notice how fast the rear hatch and rear window get completely covered in road grime spray, etc? Could just be that the weather is always terrible here in MN but seems to get coated with grime very quickly even when roads are clear. Has anyone tried mud flaps? Do they help? Any thoughts appreciated.
Pete6114
Ontario, Canada
I got mud flaps and like them, but they don't do anything to keep the lift gate window clean. Every Suv and crossover we had was like that. Just cant be helped...
Artie
Georgia
It’s a major drag having a freashly detailed vehicle pick up grass clipping and storing them on the bumper while driving through your neighborhood. Their needs to be some change to the rear spoiler that directs some airflow off the roof and down the rear. I don’t think this will ever be done because it would cause a .02% reduction in MPG.
yes, it’s very annoying.
mhExped
I also tried mud flaps only to find they don't help with the rear window in any noticeable way.
As far as SUVs go, I can only compare with Ford Flex and Acura MDX. This '18 Expedition is BY FAR worse in this regard.
Lou Hamilton
Maryland
My Pilot was just as bad. It just did not show it as much due to the color (Mocha/Beige).
White is bad, but not as bad as a black vehicle.
aggiegrad05
North Texas
This is nothing you all don't already know, but...
It's because of the flat back. That's why SUVs have rear wipers and sedans don't. The slipstream in a sedan carries air over the entire length of the vehicle and the dead zone doesn't occur until far beyond the rear window, i.e. behind the trunk. In that dead zone, you get a vortex of slowly swirling air that sucks up any fine mist or grime. The dead zone in a flat-backed SUV happens immediately against the rear window so all that sucked up "stuff" is just deposited on the window. The Expi probably has it a bit worse because of the lip right at the top of the hatch with the CHMSL. That lip will have its own little dead zone immediately underneath it. Were they to remove that lip, it might help but it certainly wouldn't eliminate the issue. The only way to prevent this from happening would be to give the vehicle a tail so the slipstream would be pulled beyond the rear window...which would not be a good look.
Here is a Golf as a stand-in for a flat-backed SUV (I know, I know, it's not an SUV, but it has a flatter back so you can see the effect). Notice the dead zone behind the window. Side note: the Golf does have a rear wiper as a result.
Here is a regular sedan. Notice the dead zone doesn't appear until behind the trunk.
Black
Kentucky
This is exactly why I swapped to the regular wiper arm on my 2016 so I can just buy the standard 17" wipers and change them frequently. I am on gravel constantly so I just keep a nice stock of wiper blades and fluid.
1970Maverick
orlando, fl
What arm did you use to convert your rear wiper?
Black
Kentucky
Plati
Black
Kentucky
Or buy a Trico that fits the OEM arm for $10 and works fine. That's what I do on my 2014.
Pretty sure 15+ use a different setup than earlier models. This could not find anything other than the OEM style.
sjwhiteley
Kentucky
As already noted, this happens with all SUVs. I have found it ‘cleaner’ than my old 2009 Chevrolet Suburban.
Shutterbug57
Ohio
The real reason not to do as you say is it would add lift to the rear end. Not a desirable outcome.
Artie
Georgia
A friend of mine had this model Subaru with this factory spoiler, it made a massive difference on the rear deck lid in regards to dirt accumulation. I’m not suggesting anything drastic, nor do I hold any education in aerodynamics so talking out of my ass is a real, and probably frequent, possibility.
