Rear Sway bar?
D
Deadman
Wisconsin
Just ordered a Hellwig rear from Summit, I'm excited to see the difference especially when towing! I watched the 3rd row passengers head movements on a road trip last week and it looked like they were riding on a school bus back there.
My kids told me they thought something was broken as they rear swayed and bobbed so bad they thought something literally broke. It had 400 miles on, brand fn new. I was sooooooo disappointed, I almost had buyers remorse. Then I found the Hellwig bar, and then the ******* at Hellwig stayed in their moms basement for months hiding from the media's puppet Covid, so I had to wait for like 3-4 months for it.
5280tunage
colorado
It's not the end links, it's the bushings holding the bar to the frame rails. I've had the same noise on other vehicles, often it's the composition of the bushings, if you could write the sound it's more of a rear-rear-rear, only really when going over speed bumps/humps.
techdude99
US
You guys may want to try some sumo coil springs. I tow a 6000 lbs trails from time to time and this completely erased all of the bounce and squat. Normal driving is a tad stiffer when turning....the side sway stopped significantly.
Jay Mac - Is your suspension CCD or passive? I think Deadman mentioned they didn't help with cornering (not including Sport mode) on his OEM CCD.
The bounce and sway bother me and my family. I didn't pick up a truck with CCD, but I'm reconsidering Sumo Springs because I picked up a set before I took delivery of my trailer based on several posts stating they correct for squat. After adjusting the ball height on my Weight Safe hitch to the correct weight distribution setting, there's barely any squat and it handles confidently while towing.
The OEM CCD handing, as Deadman described several times (along with political commentary that reminds me of my crazy uncle ;) ) confirms what I've read from various sources.
Deadman - thanks for staying active in the thread to post your first hand experiences. It made me take a second look at sway bars when I was considering stiffer springs.
A few questions for thread participants:
  1. Has anyone considered keeping the OEM sway bar and replacing the rubber bushings with Urethane (I believe ES makes a generic set that may fit) or high density rubber or injecting the OEM rubber with a stiffening agent, like 3M window weld?
  2. Is the Hellwig bar hollow or solid? From what I can see, it appears solid.
  3. Are there any other quality brands worth considering?
5280tunage
colorado
The OEM CCD handing, as Deadman described several times (along with political commentary that reminds me of my crazy uncle ;) ) confirms what I've read from various sources and was the main reason I didn't consider CCD for my configuration.
  1. Has anyone considered keeping the OEM sway bar and replacing the rubber bushings with Urethane (I believe ES makes a set) or high density rubber or injecting the OEM rubber with a stiffening agent, like 3M window weld?
The hellwig bars are definitely solid. Very heavy. Unfortunately my experience was not great with the parcel service, the first one they delivered as an empty box, the bar must have fallen out at some point, funny that the label said over 50 pounds and the delivery driver delivered a box that weighed about a couple pounds. Ridiculous.
I've had hellwig on previous vehicles. High quality. It was one of the first things I did on this, well worth it.
@techdude99, curious, if you do find some replacement bushings for the end links, I would love to know, technically I can't stand the design of the factory end links. Metal on metal? Heck, I would even like complete end link replacements. I also sent an email to hellwig to see if they have upgraded bushings for the bars.
D
Deadman
Wisconsin
My sway bar boxes were in rough shape as well...... I was afraid parts were missing, but they were not.
Gillbrak
Denver
Good info here and thinking of upgrading to these. Leary of the bushing squeak though. Is the ride worth it? We have a platinum w CCD. We have a TT that is about 8K lbs loaded.
5280tunage
colorado
And again I really only hear in when the windows are down. And I'm just more **** than most. I'd say well worth it.
techdude99
US
I'll create a post if I find a good solution.
I think I'll give the Hellwig a try. If anyone's aware of a reseller that offers a holiday discount, please PM.
mwl001
Scottsdale AZ
Has anyone had any issues with Ford service after installing these? Is this considered a wear item anyway and a non-issue? Thanks to anyone who has any knowledge, never done anything like this to a vehicle under warranty before.
